Want to swap cams but worry about mess up timing belt
i have never replaced the cams on b16 engine before but i have a repair manual and basic car mechanic knowledge, i know what to do to get all bolts loose and to get cams out but i am worry about mess up timing belt. so i need some advise before i can do this.
also do i need to apply lubricants all over the new cams, what kind of lubricants to use.
thanks .appreciate
Modified by Powered by VTEC at 8:51 AM 1/23/2008
thanks .appreciate
Re: Want to swap cams but worry about mess up timing belt (Powered by VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Powered by VTEC »</TD></TR><TR><TD CLASS="quote">i have never replaced the cams on b16 engine before but i have a repair manual and basic car mechanic knowledge, i know what to do to get all bolts loose and to get cams out but i am worry about mess up timing belt. so i need som advise before i can do this. </TD></TR></TABLE>
I keep it simple by setting the engine to TDC and then using a paint pen to put a dot on the timing belt to show where the cam gears are straight up. It's pretty hard to mess this up if you just take a little time and double/triple check everything.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Powered by VTEC »</TD></TR><TR><TD CLASS="quote">also do i need to apply lubricants all over the new cams, what kind of lubricants to use.
thanks .appreciate</TD></TR></TABLE>
Any auto parts supplier should have assembly lube. Be sure to apply liberally
boomersz
04-05-2007 11:14 PM
MikeSarr_GSR
12-03-2002 11:19 AM
