removing rear seats in 5th gen sh
Old Nov 28, 2005 | 01:30 PM
fastboy501's Avatar
Default removing rear seats in 5th gen sh
anyone done it? where are the screws/clips located if so. so that i dont break anything pulling it off
Old Nov 28, 2005 | 01:32 PM
wtfitzsoda's Avatar
Default Re: removing rear seats in 5th gen sh (fastboy501)
i remember having two clips under the seats where the seats touch the carpet... remeber to pull those clips before trying to remove the seats... everything else should be easy... a few bolts and done deal
Old Nov 28, 2005 | 01:33 PM
AndyD's Avatar
I think they are just like the 4th Gen rear seats. If so, reach under the front of the seat cushion and you will feel a plastic tabs that can be pulled towards the front of the car. There should be two tabs for each seat cushion.
Pull each one CAREFULLY forward and lightly pull the seat cushion up. It will come out pretty easily
Old Nov 28, 2005 | 07:40 PM
incubus's Avatar
Default Re: removing rear seats in 5th gen sh (AndyD)
there are only two plastic tabs to pull, one on each side about half way thru each sides cushion. also there is a 10mm (may be 12mm) bolt by the seat belts in the center that holds the bottom cushion on. thats it.
Old Nov 29, 2005 | 10:53 AM
fastboy501's Avatar
Default Re: removing rear seats in 5th gen sh (incubus)
thanks, im gonna go try it now! ill let u know how it went and what i broke... lol jk
Old Nov 29, 2005 | 11:02 AM
chihuahuamanx's Avatar
i just did it last week. Pull the tabs, and lift the bottom part out. The top part is secured with two L brackets on the lower part of the rear, connecting the rear section to the inner quarter panels.
Its easy, took me 5 min.
Old Nov 29, 2005 | 11:15 AM
PRELUDE-GT35R's Avatar
I took it out 5 years ago, try to save some weight. The next day I put everything back...why ??? Cause' you r not gonna save any LBS at all. Them rear seat weight not thing. Let me know after you take it out
Old Nov 29, 2005 | 12:21 PM
Default Re: removing rear seats in 5th gen sh (PRELUDE-GT35R)
weight is one thing but if you ask some people, a stripped interior just looks sick. It's 100% a matter of opionion, but right now, I like the look of a stripped interior.
To each his own.
Old Nov 29, 2005 | 09:28 PM
1GPlusSH's Avatar
Default Re:
I took mine out to save weight and put them right back in when I realized that it wasn't worth the look. I wonder if those things even weight 15lbs.
janeee04
Mar 25, 2008 11:38 PM
rch022
Jan 3, 2008 05:38 PM
B18c5__Owns
Apr 24, 2007 07:01 PM
vinuneuro
Nov 8, 2005 07:53 AM
optikal_blitz
Jan 29, 2003 02:09 PM
