Window tinting removal
Old Nov 28, 2005 | 10:16 AM
athoughts's Avatar
Default Window tinting removal
Well ive recieved two fix it tickets for my front windows being tinted. what is the easiest way to remove the tint?
Old Nov 28, 2005 | 10:19 AM
Built to Spill's Avatar
el diablo
Default Re: Window tinting removal (athoughts)
razor blade or some type of scrapper. Then wash the inside of your windows after its pulled.
Old Nov 28, 2005 | 10:23 AM
94hatchling's Avatar
i removed all of mine when i bought my hatch. all old, and purple.
i used a razorblade in a scraper, and a spray bottle with rubbing alcohol to remove the residual adhesive. its a pain in the ***, but can be done. oh also, if you can let it sit in the sun or remove it somewhat warm, its a lot easier. goodluck!
Old Nov 28, 2005 | 04:07 PM
jrod647's Avatar
Default Re: Window tinting removal (aallbbeerrtttttt)
I had to remove the tint on may car and i just took a razor blade and scraped it off then went to the store and bought some adhesive remover.
Old Nov 28, 2005 | 04:16 PM
Redcoupe's Avatar
Default Re: Window tinting removal (jrod647)
Just don't use the razor blade on your back window.
Scrape a piece up, then spray it down with simple green, wait.. and start to pull.
It's easy to do, just time consuming.
Good luck with it, if you need any more help, IM me and I'll be glad to help you.
Old Nov 28, 2005 | 04:18 PM
ZCVTEC-SOHC's Avatar
From: PhantomGrayEH2, CA Where Gay Arnold Rules, USA
Default Re: Window tinting removal (Redcoupe)
Seriously don't use a razor blade on the back window, I learned the hard way.
Old Nov 28, 2005 | 04:46 PM
DestructoEH's Avatar
The easiest way I've found on front/passenger windows is to roll the window down a bit and slide a blade into the tint along the top edge near the corner. Once you get that peeled out, begin to peel the tint back, and roll the window up as necessary. There will probably be adhesive left over, so spray the window down with ammonia (we use stuff called "Ammonia T-Stripper"). Give the ammonia about 15 seconds to do its work and use a razor blade or superfine #00 steel wool to remove the adhesive.
For the rear glass, peel away a small corner (be careful of the defroster wires) and gently but steadily continue until the tint is out. Spray down the window with ammonia and use the superfine steel wool to get the adhesive off. If you don't have steel wool, i would try to just get the adhesive real saturated with ammonia until it gets soft and runny and use a cloth to wipe it away.
This works for me at work and I've never scratched glass or ruined rear defroster wiring. Just make sure not to use regular *** steel wool.
Old Nov 28, 2005 | 04:47 PM
ej6ian's Avatar
I took mine out with an exacto knife and theres still glue left on the window.
Hey thanks for the advice with the steel wool ! Im going to have to try that.
accord99power
Dec 12, 2008 08:35 AM
JDM_Frijoles
17
Apr 19, 2007 11:28 AM
YNOT
Nov 4, 2003 10:15 AM
piaadoll
25
Jul 26, 2003 12:05 PM
gokuson
Jun 21, 2002 01:24 PM
