DA sidemarker condensation....how do I fix this?
Old Nov 28, 2005 | 06:08 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default DA sidemarker condensation....how do I fix this?
Does anyone else have this problem? I know I can check the rubber seals againts the light bulb socket to make sure they're good, but is there anything else I can do to stop this? It's more annoying than anything, I wonder if it's possible the seals are bad between the lens and the housing and I need to seal them up like I did the headlights...TIA
Chris
Old Nov 28, 2005 | 11:10 AM
Default Re: DA sidemarker condensation....how do I fix this? (DAantagonist)
15 hits and no answers....wow. Anyone...?
Old Nov 28, 2005 | 11:14 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Yes, you need the check the seal between the lens and housing as well as the bulb socket.
You can use a silicone sealant or Goop.
Old Nov 28, 2005 | 12:06 PM
Default Re: DA sidemarker condensation....how do I fix this? (carma_626)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carma_626 &raquo;</TD></TR><TR><TD CLASS="quote">Yes, you need the check the seal between the lens and housing as well as the bulb socket.
You can use a silicone sealant or Goop. </TD></TR></TABLE>.
thank you sir...I wanted to make sure this wasn't a on going problem that all of them have had. I considered just getting new ones and not having to deal with it...I'll take a look...thanks again.
xaznxdrgnxboix
Honda Civic (2006 - 2015)
Aug 12, 2008 02:36 PM
patrickstar
Jan 28, 2008 02:53 AM
gsr-2nr
Jul 18, 2004 04:52 PM
cjames235
Jan 26, 2004 09:30 AM
1sikcoupe
Jun 29, 2003 05:39 AM
