Sound like a cracked sleeve? Need advice
Old Nov 28, 2005 | 12:08 AM
Nisif's Avatar
Default Sound like a cracked sleeve? Need advice
Unfortunately I have experienced some issues with my dizzy, it was throwing a code 9, (believe the ignitor was going out). Problems kind of arised out of the blue, after making a quick trip I noticed my car started cutting out, mainly under light throttle loads (especially 5th gear highway cruising), but it continued to get worse on my way home. When I got home, I ended up swapping out the ignitor for a new one, however, after I took the car for a quick drive the next day my car starting pouring out white smoke right before I made it home. It was to the point where the car behind me couldn't barely see the road. I've just finished a compression check and all 4 cylinders are at 240 psi. I'll be doing a leakdown test on Tuesday morning once I have my hands on a air compressor. What I am looking for? Where will the escaping air exit if I have a cracked sleeve? Thanks in advance for the advice or any suggestions
Old Nov 28, 2005 | 03:44 AM
doublej's Avatar
Default Re: Sound like a cracked sleeve? Need advice (Nisif)
Once you remove all spark plugs look for water in cylinder(s). Then perform leakdown test w/ radiator cap removed to observe coolant level change or bubbles. Do all 4 cylinders regardless of any obvious problems. Then let us know results.
Jim
Old Nov 30, 2005 | 06:21 AM
mo0cow's Avatar
does your car have a hard time starting? and does it stutter?
Old Dec 14, 2005 | 03:06 PM
Nisif's Avatar
Finally got time to do a leakdown test and all 4 cylinders were no greater than 10% leakdown, and my compression was 240psi across the board. Any ideas? Like I said before the car was pouring out white smoke smelled like burning oil.
Old Dec 16, 2005 | 07:39 AM
Nisif's Avatar
Bump...need some suggestions really like to know what to look for b4 pulling the head
Old Dec 16, 2005 | 07:40 AM
Nisif's Avatar
Is it possible to have good compression/leakdown numbers and still have a cracked sleeve?
Old Dec 16, 2005 | 02:15 PM
minimesleeper94's Avatar
white smoke-------head gasket
Old Dec 16, 2005 | 02:18 PM
it's not a cracked sleeve. and you won't find your problem unless you go looking for it.
thanh4o8
Dec 8, 2009 08:18 PM
LSV_REX
Oct 14, 2008 05:38 PM
TheDahliaLama
Jun 13, 2006 04:59 PM
ttmitsu
Oct 11, 2005 11:14 AM
95c1v1cs1
May 23, 2003 08:40 AM
