my car still idle so high...2k start up, 1k warm up
Old Nov 27, 2005 | 07:51 PM
lv6l's Avatar
Default my car still idle so high...2k start up, 1k warm up
my car idle very high, 2k when its cold and 1k when its hot, 1.5 average when i stop and go. i check my timing, everything is good. my cam gear did jump a few teeth but i correct it already. what else could be the problem?
Old Nov 27, 2005 | 08:13 PM
EG2Driver's Avatar
Default Re: my car still idle so high...2k start up, 1k warm up (lv6l)
thats how my sol always idle. What engine do you have?
Old Nov 27, 2005 | 08:16 PM
dohcVTECeg2's Avatar
Default Re: my car still idle so high...2k start up, 1k warm up (deadend9009)
yea when its cold out and i start my sol in the morning it idles at 2k then once its a lil warm it drops to a lil less then 1k
Old Nov 27, 2005 | 09:38 PM
lv6l's Avatar
stock cx motor. d15b8. people been telling me it should idle at 650rpm. but i'm getting 1k at the lowest. normally its at 1.3-1.5
Old Nov 27, 2005 | 09:45 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (lv6l)
reset idle speed....
1. warm up engine
2. Turn off all loads and disconnect IAC
3. Adjust idle screw so engine idles around 480
4. Shut off car, reset computer and plug in IAC
5. Start car and let it idle for 5 minutes
Should be cool after that, unless you got mechanical problems
Old Nov 27, 2005 | 11:07 PM
lv6l's Avatar
where can i find the plug to disconnect the IAC. also, i have an rpm off an ex cluster and i see the number 1 and the number zero with a line right above it. is that little line(close to the bottom line)500rpm or 0rpm?
Old Nov 27, 2005 | 11:24 PM
Luserkid's Avatar
Default Re: (lv6l)
Do you know where your IAC is? If not its behind your manifold.
I recommend getting a digital timing light, they tell you correct engine speed.
Old Nov 28, 2005 | 12:05 AM
lv6l's Avatar
ok, my idle seem to be ok, but now i have a bigger problem. i notice when i was waiting for my car to warm up, my fan neve turned on. so i thought it was slow, i finish up the process of what Evs-One told me to do than was suprize it fixed my idle, but than i look at my temp and it was about to overheat! i dont know when my fan stop working but i was driving about an hour earlier and the needle didn't go anywhere near the middle. i had the temp in the car's climate control **** on hot when i was driving but did not turn on the climate fan. i didn't see the neddle go up on the temp gauge, but now my car's radiator fan wont go on and my car is close to overheating, needle goes close to up high and i stop and here i am now on honda-tech. asking you guys. HELP
Old Nov 28, 2005 | 12:09 AM
vancoland's Avatar
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">where can i find the plug to disconnect the IAC. also, i have an rpm off an ex cluster and i see the number 1 and the number zero with a line right above it. is that little line(close to the bottom line)500rpm or 0rpm?</TD></TR></TABLE>
that little line right above the zero is 500. some people mistake it for 100 or 200 and think that they are idling lower than they actually are
Old Nov 28, 2005 | 07:42 AM
Luserkid's Avatar
did you check your fan fuse? Also did you check to make sure everything was plugged in correctly for it to work?
Old Nov 28, 2005 | 07:56 AM
mikeunreal's Avatar
Default Re: (Luserkid)
mine idles exactly like this too, and i have a b16
Old Nov 28, 2005 | 08:37 AM
lv6l's Avatar
yeah all fuse are ok looking and i plug everything back.
Old Nov 28, 2005 | 08:38 AM
duggy's Avatar
This is what I did when I had a 3k cold idle and a 2.5k warm idle.
1. Take off your TB.
2. Under your TB should be your FITV.
3. There are 3 screws holding that on. Unscrew it.
4. There is a cap on the FITV with two Phillips screw. Take that off.
5. Inside, there is a white diaphram, if it is backed out, turn the white screw with your hands in a couple of turns. Keep doing this until your idle gets better.
Old Nov 28, 2005 | 03:26 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: (lv6l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lv6l &raquo;</TD></TR><TR><TD CLASS="quote">yeah all fuse are ok looking and i plug everything back.</TD></TR></TABLE>could be the fan relay, fan switch or motor.Jump the motor straight off the battery and see if it works. If it does, you know it's either a fuse/relay/connection/sensor, etc
Old Nov 28, 2005 | 06:50 PM
lv6l's Avatar
oh, thanks you guys, my radiator fan works now, it turn out, ther was a harness near the dizzy that was unplug. but as i was raeding, duggy post his directions to check out the FITV. i have tried doing that before, i took off the throttle body and stuff and can't seem to find the FITV. could my car be missing this? would a car run if it was missing this? what does the FITV look like and how big is it? maybe i'll take it off again and give it another shot.
DaX
Oct 24, 2018 04:56 AM
kUrb3d
Aug 16, 2010 11:20 AM
b18cisbetter
Dec 8, 2009 06:04 AM
phill
Sep 9, 2004 08:01 AM
sporkcrx
Oct 22, 2002 04:13 AM
