Help!!!!!!!
Old Nov 27, 2005 | 06:40 PM
crxvtecred's Avatar
Default Help!!!!!!!
After I installed my Walbro fuel pump and replaced my main relay, my car was running great. The next day my fuel pump sounded like it was struggling. Then I turned the motor over and it started right up but then died. Wondering why it died, I checked my fuses and my alternator seloniod valve fuse blows everytime I try to start the car. I have checked all the grounds and voltage and everything seems fine. The next thing I have to check is the fuel pump. Any suggestions as to what would cause this?
Old Nov 27, 2005 | 07:47 PM
Markb16a's Avatar
well to install a Aftermarket Fuel pump or any puel pump you have to take the gas tank down and put the fuel pump from underneath. Well when u do that you might of have pinched a wire. Well thats what happened to me when we installed a 255 walbro fuel pump in my car. Well if anything check to see if you pinched a wire. That would probaly be your problem. Hey if you do that put a jack underneath the gas tank so you can just jack it right back up without using your body strength. Just to help you out.
Old Nov 29, 2005 | 03:40 PM
crxvtecred's Avatar
Default Re: (Markb16a)
Thanks for the advice!!!
lmananT
Jun 4, 2008 10:56 PM
huge230
Jun 19, 2007 02:58 PM
arospeedintegra
Mar 6, 2007 02:26 PM
yellowrexturbo
Oct 9, 2004 03:36 PM
dyases
Apr 30, 2004 06:45 PM
