Spring Compressor??
Im planning on putting some H&R springs on my DA and im just wondering if i need a spring compressor to take of the originals and obvisouly to put on the new ones???...thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra3586 »</TD></TR><TR><TD CLASS="quote">you will need a spring compressor to remove the stock springs safely usually u dont need any kind of spring compressor to put the new lowering springs on
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integra3586 »</TD></TR><TR><TD CLASS="quote">you will need a spring compressor to remove the stock springs safely usually u dont need any kind of spring compressor to put the new lowering springs on </TD></TR></TABLE>
watt?? i had to use it to take the old off and put the new ones on...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquid Ice NF »</TD></TR><TR><TD CLASS="quote">
watt?? i had to use it to take the old off and put the new ones on...</TD></TR></TABLE>
i said usually, i am going off my personal experience. i have installed a lot of lowering springs, and i have not had to use a spring compressor on any of the setups i worked on,
obvioulsy it depends on how much of a drop it is, my experience was with 2-3 in drops, tenzo r, neuspeed, matrix, tokico
since DA springs arn't compressed as much as lots of cars you can put the spring/shock assembly sideways and put a skateboard on top of the spring and make it work like a blocker that's what i did (don't blame me if you get hurt though)
I installed some Nuespeed Sport springs without a spring compressor, there wasn't that much pressure on the original springs. I just used a towel wrapped around the shock/spring assembly and backed off the top retainer bolt. It was cake, and putting the Nuespeed spings on my AGX's just took alittle pushing to get the top nut started. No need for a spring compressor on my 92 RS.
i used to let the springs shoot out. i had my foot on the bottom end of the shock and then loosen the bolt and then had a bucket on the other end to catch everything. i did that on all the cars i dropped. except for when i did a '02 accord V6. i wasn't gonna risk doing that. also the spring to big. anyways, use the compressor. i haven't had to use to compressor to put lowering springs back on.
go buy a freaking spring compressor....they are cheap...
stock springs are the ones pre-loaded, buy the tool now you will thank yourself when you use it again
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller »</TD></TR><TR><TD CLASS="quote">go buy a freaking spring compressor....they are cheap...
stock springs are the ones pre-loaded, buy the tool now you will thank yourself when you use it again</TD></TR></TABLE>
i know u can rent them from autozone.. well actually yu put a deposit down.. and u can keep them if u want.. but dont, cuz they charge like $40
yea thats what i did for my chevelle i kept the compressor....only its an internal spring compressor.....i mine as well buy one for the friend who one day will need it
