jdm h22 vtec pressure valve issue (I SEARCHED)
Old Nov 27, 2005 | 12:41 PM
kaoss_11's Avatar
B A N N E D
Default jdm h22 vtec pressure valve issue (I SEARCHED)
I have searched for a few days now and i have tried everything. I checked all of my connections and the black wire is grounded to my thermostat housing like everone says and the blue/blk wire is connected to d6 through the stock wire loom. I also changed my entire vtec solenoid and pressure switch the code still pops up. I have cleaned every screen there is i have also tried another ecu.
What else can i do or is there some type of way to bypass this?
Setup: jdm h22, chipped ecu that all the info thats relative to this issue.
Old Nov 27, 2005 | 02:22 PM
kaoss_11's Avatar
B A N N E D
up
Old Nov 27, 2005 | 02:50 PM
duggy's Avatar
You have enough oil? Is your speedo working? The reason I am asking that is if you do not have enough oil, VTEC will not kick in.
If your Vehicle Speed Sensor is not working, then you will not have VTEC either.
What kind of chip is it?
Old Nov 27, 2005 | 04:05 PM
kaoss_11's Avatar
B A N N E D
speedo works and i have enough oil and chipped by phearable.net
Old Nov 27, 2005 | 05:59 PM
kaoss_11's Avatar
B A N N E D
help
Old Nov 28, 2005 | 08:03 AM
mtber's Avatar
Default Re: jdm h22 vtec pressure valve issue (kaoss_11)
Try jumping the vtec oil pressure signal wire onto the vtec solenoid wire at the ecu plugs...
Old Dec 4, 2005 | 06:41 PM
kaoss_11's Avatar
B A N N E D
I put my car in the shop and come to find out my crankshaft was shot. They changed my oil pump and the psi was @5 so my crank is at another shop getting polished and etc so hopefully everything will be good this week. I will keep everyone updated.
Old Dec 13, 2005 | 08:01 PM
kaoss_11's Avatar
B A N N E D
Default Re: (kaoss_11)
pressure fixed still throwing code 22. Has anyone else had this issue I have searched through many threads and still nothing.
Old Apr 3, 2007 | 08:32 AM
fastcrx420's Avatar
i'm getting a code 22 with a z6 123k on the motor no swaps. everything is hooked up new screen/gasket and everything
Old Apr 14, 2007 | 07:18 AM
wernhersey's Avatar
bump for more info.
Im having the same problem and I aslo had a low oil pressure problem due to bad rod bearing. now fixed and still throwing the same code
See Are X
Sep 4, 2024 03:31 PM
hondamyheart
15
Aug 5, 2018 11:24 PM
tbgallant
Aug 16, 2013 10:41 PM
Bimmerman
Jun 15, 2005 05:23 PM
digital sol
Oct 30, 2004 12:07 PM
