problem with my b16 swap
Old Nov 27, 2005 | 11:49 AM
StreetSleeper's Avatar
Default problem with my b16 swap
i swapped a b16 into my crx and now the check engine light is on and the light on the ecu will flash seven times but i cant find the proplem, if anyone could give me some advise on how to handle this problem that would be great.
Old Nov 27, 2005 | 11:58 AM
Redline130's Avatar
Default Re: problem with my b16 swap (StreetSleeper)
Code 7 is your TPS sensor. Was your car DPFI previously? If so, did you switch the wires around on the TPS sensor plug?
Old Nov 27, 2005 | 12:03 PM
Ass$nyper's Avatar
Pirate General...YARRRR
Default Re: problem with my b16 swap (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">Code 7 is your TPS sensor. Was your car DPFI previously? If so, did you switch the wires around on the TPS sensor plug?</TD></TR></TABLE>
good call this happened to me my first b16 swap
Old Nov 27, 2005 | 12:08 PM
Autoworks's Avatar
or you could have either a bad TPS or TPS is out of adjustment
Old Nov 27, 2005 | 12:11 PM
ya it was a DPFI and i do not think i switched the wires so i am going to go try that and see if that works. thanks
Old Nov 27, 2005 | 02:37 PM
ppl talk bout my old name's Avatar
tps just change it and find out if its bad its a cheap sensor i pop them all the time with all the boost
GOT BOOST?
Old Nov 27, 2005 | 05:22 PM
31flavorscivic's Avatar
Default Re: problem with my b16 swap (ten second crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ten second crx &raquo;</TD></TR><TR><TD CLASS="quote">tps just change it and find out if its bad its a cheap sensor i pop them all the time with all the boost
GOT BOOST?</TD></TR></TABLE>
explain please
Old Nov 27, 2005 | 05:32 PM
zccr-xsi's Avatar
u could a have open wire.u can straight wire it by cutting the cilp off the engine harness.take 3 wires repin them in the tps clip,then run them though the firewall and solder them to the 3 tps wires at the ecu thats how i fixed mine.
Old Nov 27, 2005 | 05:42 PM
b16crx0062004's Avatar
here u go ............... https://honda-tech.com/zerothread?id=468260
Old Nov 27, 2005 | 10:06 PM
crxsi8's Avatar
Helpful imformation!can be used in the future
steve0527
Dec 11, 2006 05:53 AM
teler86
Mar 3, 2006 03:45 PM
TYPErCRX
Apr 24, 2005 10:17 PM
sLoWrAcEr
10
Apr 24, 2005 03:34 PM
type Gendy
Mar 7, 2003 10:12 AM
