can i run obd2 ecu with obd1 h22 and obd1 dizzy
Old Nov 27, 2005 | 11:35 AM
civic93@8psi's Avatar
Default PLEASE HELP can i run obd2 ecu with obd1 h22 and obd1 dizzy
heres the deal put a jdm h22 into a 99 lude now im running obd1 dizzy ecu and motor and it keep stalling out when i stop and it dont like to idle to long
help help help
also running obd2 injectors and got cel 12 EGR
thanks
-mike
Modified by civic93@8psi at 1:04 PM 11/27/2005
Old Nov 27, 2005 | 12:05 PM
ANY ONE
Old Nov 27, 2005 | 12:06 PM
Boarderx192's Avatar
Default Re: (civic93@8psi)
I think you need to run either all OBD 1 or all OBD 2. Look in the faq section. Theres a right up as to what you need to do
Old Nov 27, 2005 | 12:07 PM
mgags7's Avatar
lets make a checklist here:
obd1 ecu: check
obd2 injectors: check
obd1 & obd2 mismatch: check
i wonder why it doesnt work right....
Old Nov 27, 2005 | 12:15 PM
Question is can i run obd 2 ecu with obd 1 dizzy i took and wired up every thing from by the crank into the obd1 dizzy
-thanks
mike
mariog96teg
Dec 12, 2013 10:03 PM
JdM_Eg6_SiiR
Engine Management and Tuning
Dec 6, 2010 07:12 AM
1hotvtec
Oct 12, 2003 07:29 PM
quikB18B
Apr 14, 2002 08:48 AM
