what mounts do i use for a sir 2 into a 1994 honda civic ex
From: With my POS D15B2, Whereever whenever, United States
all mounts work except the t mounts and the front torque mounts i believe
94-01 integra rear 'T-bracket-
94-01 Integra Upper 'Timing-Belt' Mount
You need An Integra or B16 A/C Bracket.
Everything else you can use your stockers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OneFiveAlive »</TD></TR><TR><TD CLASS="quote">
You need An Integra or B16 A/C Bracket. </TD></TR></TABLE>
To be more precise, a 1995 Del Sol VTEC A/C bracket. If I am not mistaken it's the P54 Bracket.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6hatch94 »</TD></TR><TR><TD CLASS="quote">stock should work.. worked for my cousin
If i remember correctly, the d-series bracket will not bolt onto a B block
</TD></TR></TABLE>If i remember correctly, the d-series bracket will not bolt onto a B block
you will need all b series mounts except for the upper tranny mount. that is the only one you can reuse. If you want to retain your a/c then use a p54 delsol dohc vtec a/c bracket.
blasterman87
Jun 5, 2009 09:51 PM
