hooked up remote wire...everything went out..
Old Nov 26, 2005 | 04:34 PM
. M i c h a e l's Avatar
dotmichael to you
Default hooked up remote wire...everything went out..
got done switching head units and hooking up the system...connected the remote wire to the subs..and everything was fine for about 30 seconds. subs were hitting..all was well..then it started dimming and the head unit kept cutting out..and the dash lights were flickering.
my friend who was putting it in thought i needed a cap..15 seconds later...the interior lights all went and the head unit power was gone. did i blow a fuse somewhere? i checked the fuse under the hood and it wasnt blown..
i've been having odd electrical problems with my car in general..but would that be related to speaker wires?
https://honda-tech.com/zerothread?id=1442013
here's my thread on my cars problems...maybe somehow they're connected. thanks.
Old Nov 26, 2005 | 04:56 PM
tucker3113's Avatar
Default Re: hooked up remote wire...everything went out.. (. M i c h a e l)
check you battery and your alternator and the fuses under the dash. It sounds like a battery problem or your alternator went.
Old Nov 26, 2005 | 05:00 PM
dotmichael to you
Default Re: hooked up remote wire...everything went out.. (tucker3113)
i'll check the underdash fuses tomorrow..battery is brand new
Old Nov 26, 2005 | 08:24 PM
sony224422's Avatar
bad alternator probably
Old Nov 27, 2005 | 01:46 PM
dotmichael to you
i just checked all my fuses. under hood and under dash..all were fine.
going outside to check alternator now..
Old Nov 28, 2005 | 04:32 PM
dotmichael to you
head unit flickers but wont power on..this happens only when the head lights are off.
head lights on..NO power at all to the head unit
Old Nov 28, 2005 | 05:04 PM
Auex's Avatar
Did you use a wire harness or did you hard wire the radio? The headlight part makes me think that you may have wired the radio's ground to the illumination lead. This would cause the radio to shut off when the headlights are on and usually will blow a fuse.
What brand radio?
Old Nov 28, 2005 | 05:12 PM
dotmichael to you
Default Re: hooked up remote wire...everything went out.. (Auex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Auex &raquo;</TD></TR><TR><TD CLASS="quote">Did you use a wire harness or did you hard wire the radio? The headlight part makes me think that you may have wired the radio's ground to the illumination lead. This would cause the radio to shut off when the headlights are on and usually will blow a fuse.
What brand radio?</TD></TR></TABLE>
my friend hooked it up. from the looks of it..there was the stock harness..and another harness in there from the pioneer previously in there...and now the JVC that was just put in. its a complete clusterfuck. and me..who knows nothing about wiring.
i'll probably end up having to drop it off at a shop..but lord knows they're gonna rape me.
Old Nov 28, 2005 | 07:09 PM
romoracing's Avatar
pull out the radio and see if the car works correctly. If so then its something with the hu or wiring.
Old Dec 12, 2005 | 10:26 PM
sony224422's Avatar
Default Re: hooked up remote wire...everything went out.. (romoracing)
you might have fried your head unit.
Old Dec 13, 2005 | 05:17 PM
GsrGilbert's Avatar
Default Re: hooked up remote wire...everything went out.. (sony224422)
did u use a seprate wiring harness? your deck will have one and ur factory one will have one going out. ur story of a friend hooking up is never a good idea. lol give us some more info.
Old Dec 14, 2005 | 03:59 PM
dotmichael to you
Default Re: hooked up remote wire...everything went out.. (GsrGilbert)
turns out all my car related problems are from the three harnesses that are in there. oem, pioneer and jvc. a lot of open wires. grounding out and touching. gonna sift through it tomorrow and figure out what is what.
bank2me
Feb 20, 2011 04:58 PM
EJason
Mar 5, 2009 10:19 AM
R-81DC2
Jun 5, 2007 09:21 AM
SpeedingHatch
Jun 7, 2006 10:06 AM
BoM
Feb 19, 2002 10:09 PM
