gsr cams for b16 turbo
i was told that gsr cams would be the best for a b series that was in the works for a turbo. i just wanted to know if there was any truth to this or if there is a better option.
They are said to be the best OE VTEC B series cams for turbo. I researched here a while back.
When I sold my car, I had to remove my CTR cams and swap the GSR's back in because the new owner is turboing it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si »</TD></TR><TR><TD CLASS="quote">go with 01 ITR. they are same as CTTR and work much better then GSR's. i just built a car with ITR's and it made 476whp and 318tq at 18 lbs
That's good. I'll be putting another CTR cam in a local guys B16, who is also turboing it. He also had the debate about GSR or ITR cams. On H-T you see alot of people using the GSR cams, but I think the biggest reason is $$. I bought my GSR cams for $100 (pair used) v/s $240 CTR/01+ITR intake cam brand new in the Honda box. I guess the only way to get a good solid answer is for someone to swap cams on a dyno.
</TD></TR></TABLE>That's good. I'll be putting another CTR cam in a local guys B16, who is also turboing it. He also had the debate about GSR or ITR cams. On H-T you see alot of people using the GSR cams, but I think the biggest reason is $$. I bought my GSR cams for $100 (pair used) v/s $240 CTR/01+ITR intake cam brand new in the Honda box. I guess the only way to get a good solid answer is for someone to swap cams on a dyno.
I have GSR cams I'm putting in my B16, but I have read that ITR are better since they have a little overlap. I have seen dyno charts of a b16 with stock cams versus the samemotor/setup with gsr cams and it made a good bit morepower...if I Can find the old thread I'll link you..
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
you can make just as much power with the gsr cams as itr's for the money they are the best oem turbo cams....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DBL »</TD></TR><TR><TD CLASS="quote">you can make just as much power with the gsr cams as itr's for the money they are the best oem turbo cams....</TD></TR></TABLE>
yea. with more supporting mods though.
AzN_Flava
Feb 14, 2005 10:31 AM
