mileage rolling
i only know how to do this on EK and DC clusters...never taken a EG cluster apart before, i assume theyre similar once you open them up...just gotta remove the speedo from the cluster, remove the needle, then the face...theres a pin that holds 4 or 5 small star shaped plastic pieces that aid in rolling the odometer...you have to remove one side carefully so that the plastic stars are not making contact with the odometer...once youve done this, they roll freely...so set the mileage, then return the pin back in place, and backwards assemble everything...
pull straight off! do not bend or pull to one side, you may break the small shaft the needles are stuck onto.... ask me how I know
rolling mileage back is easy, just take th ecluster apart, use patience too, and spreading the washer/clips apart will help you roll back one number roll at a time until they all read '0'.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sucka Free »</TD></TR><TR><TD CLASS="quote">to get the needles back in sync is the tough part. there are a couple methods of goin about that process. </TD></TR></TABLE>
how would you go about getting the needles back in sync?
bro this thread is 5 years old, if someone was gonna do it to you it has already happened i assume. if not, i also assume you have better sense than to buy from somebody you can obviously tell is trying to **** you.
cheers
cheers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oem_certified_accord »</TD></TR><TR><TD CLASS="quote">how would you go about getting the needles back in sync?</TD></TR></TABLE>
I'm curious as well.
Ask Justin Timberlake?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Speed94 »</TD></TR><TR><TD CLASS="quote">
funny guy
. i got the needle to read right again, trial & error.
</TD></TR></TABLE>funny guy
Sliced Beard
Aug 28, 2004 03:03 PM
