Msd ignition question
it just means that you don't have the msd rev limiter. it's not really a big deal to havethe limiter.
**think of it this way...--> do you want to spend the extra money or so just to have a rev limiter.
its a rev. limiter... which is different from redline.. and i dont think you want to take your car to the limiter anyways unless you are built for it, or you will just beat the hell out of your motor
the ECU's limiter is harder on the motor than the MSD's limiter. if you're the kind that crashes into your limiter, get the MSD one.
BTW, pretty much everyone i've talked to says the MSD 6A/6AL setup is pretty bad for a daily driver. most have problems with it spontaneously dying and leaving them stranded within a year or so. just a "heads up."
