no vtec?
Old Nov 25, 2005 | 06:07 PM
blackie's Avatar
Default no vtec?
i noticed that vtec isnt kicking in on 2nd gear. it does in 3rd but not in 2nd. what could it be? its pretty cold outside and its also snowing (if that has anything to do with it).
Old Nov 25, 2005 | 06:10 PM
blackie's Avatar
this is all of a sudden. its been kickin in fine before that.
Old Nov 25, 2005 | 06:11 PM
littleredcivic's Avatar
VTEC has to have a couple engine parameters: engine speed, oil pressure, coolant temperature, vehicle speed. if one of the mentioned are not correct, VTEC will not function. it is also possible that there is VTEC but you can't hear or feel it. check valve lash, timing and expendible products.
Old Nov 25, 2005 | 06:14 PM
imskatencrzy's Avatar
Default Re: no vtec? (blackie)
check you vtec solenoid. if you dont know it is on the rear/passenger side of the valve cover. take it out and clean it with electric motor cleaner. also check oil level and psi. good luck bro.
Old Nov 25, 2005 | 06:29 PM
blackie's Avatar
thanks for the replies. ill start with what imskaten said. this only happens on 2nd gear.
pokmijn
Dec 27, 2007 07:27 AM
em1_fox
Oct 11, 2007 06:27 PM
goforbroke
Feb 24, 2003 04:47 PM
Teal95Coupe
Nov 25, 2001 06:29 PM
Flux
Oct 9, 2001 01:29 PM
