ITR OEM exhaust fit a 95 GSR?
Old Nov 25, 2005 | 02:31 PM
c2etalon's Avatar
Default ITR OEM exhaust fit a 95 GSR?
Im buying a ITR oem cat back, will it bolt right on to my 95 gsr or will i need a new cat/header or are they the same?
Old Nov 25, 2005 | 02:35 PM
kchungb17a's Avatar
Default Re: ITR OEM exhaust fit a 95 GSR? (c2etalon)
It won't fit w/o modification to the B pipe, which any muffler shop can do. The GSR is a slightly smaller diameter pipe. You can chop the front off your GSR B pipe and have it welded to the ITR B pipe.
Old Nov 25, 2005 | 02:48 PM
c2etalon's Avatar
Default Re: ITR OEM exhaust fit a 95 GSR? (kchungb17a)
The part that connects to the GSR cat you mean? Would I be able to just get a ITR cat?
Old Nov 27, 2005 | 07:46 PM
kchungb17a's Avatar
You can try, but I don't know if the length will be correct or not. Also an ITR cat will need the second 02 sensor hole plugged since you're OBD1. You can also get an aftermarket cat and have flanges welded to that. A lot of trouble for a stock exhaust, in my opinion.
Logan McGrew
Dec 7, 2018 06:17 PM
slowB20ej8
Apr 9, 2008 07:35 PM
Freshazzburu
Feb 23, 2005 05:24 AM
BlackGSR
Sep 2, 2001 05:40 PM
jabroni95gsr
Aug 27, 2001 06:09 AM
