running 38 and 42 offset. will it be a problem?
if i run one 42mm offset wheel and three 38mm offset wheels on my car, will this cause a problem?
also/or
run two 42mm on one side of the car and run 38mm on the other side of the car,
how will these options work/not work out?
why do i ask a weird question? i made a huge dent on one of my wheels and i found a guy who can get wheels real cheap. problem is i don't want to spend more money than necessary. don't we all...anyways, imput is appreciated.
also/or
This is how IT SHOULD BE DONE if you have rims with different offset
If you have ET38 and ET42, this is how it should be
ET42 - both must be in the front
ET38 - both must be in the rear
Don't ever put one offset to the left side off the car and the other offset to the other side...
Always use rear-front combination...
And always use 2+2 pattern... 2x ETXX and 2x ETYY
L4NDO
Mar 30, 2003 03:04 PM
