LS/vtec question.......head gasket and block and head prep????
ok i have a ls vtec with stock ls pistions and rods and a staock b16 head....i was wondering if anyone know how much static compression ratio more can u get out of a block and head combo by shaving the head and the block more????????
Check out C-Speedracing.com. They have a compression calculator. Where it asks for head gasket thickness, subract .030 (milled head) and you will have a decent idea.
Here, I did it for you. Your compression now is roughly 9.76:1. If you mill .030 off the head, you'll be right around 10.45:1. If you also zero the deck (Piston to deck height) you will be right at 11.0:1.
Make sure you check piston to valve if you use big cams, ls pistons don't have a large valve relief cut into them.
Have fun.
Have fun.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompressionFed »</TD></TR><TR><TD CLASS="quote">Here, I did it for you. Your compression now is roughly 9.76:1. If you mill .030 off the head, you'll be right around 10.45:1. If you also zero the deck (Piston to deck height) you will be right at 11.0:1.
Have fun.</TD></TR></TABLE>
Yes like he said, Shaving the head/decking the block isn't the best way to squeeze compression only because you start to run into valve clearance problems! We just finished up a similar setup on a buddy's car but with a gsr head, it moves ok.
From: Good luck to this industry, you're gonna need it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by punkracer »</TD></TR><TR><TD CLASS="quote">where did u get that infomation.....what formula did u use???
thanks man....</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CompressionFed »</TD></TR><TR><TD CLASS="quote">Check out C-Speedracing.com. They have a compression calculator. Where it asks for head gasket thickness, subract .030 (milled head) and you will have a decent idea.
QUOTE=CompressionFed]Check out C-Speedracing.com. They have a compression calculator. Where it asks for head gasket thickness, subract .030 (milled head) and you will have a decent idea.
[/QUOTE]
THAT'S where he JUST TOLD you he got the info from...wow...read and reSEARCH homie...it's how we all learned.
[/QUOTE]
K7-1Ktrevor
Aug 24, 2009 03:40 PM
