Wats is the compression for ls/vtec
Old Apr 17, 2011 | 09:47 PM
carlossolorzano's Avatar
Default Wats is the compression for ls/vtec
i have a ls/vtec i have a 94gsr head wit a 98b18b1 block doess anyone know wat the compression should be???
Old Apr 18, 2011 | 12:57 PM
BIGPUN1's Avatar
Default Re: Wats is the compression for ls/vtec
it really depends on alot of factors. what head your using, which block, pistons, head gasket. etc etc etc. heres a link
http://www.c-speedracing.com/howto/c...c/compcalc.php
Old Apr 18, 2011 | 07:55 PM
im useing stock ls motor wit oem head gasket stock head...
Old Apr 21, 2011 | 06:59 AM
Kelb's Avatar
stock ls motor with stock head and oem gasket wouldnt be lsvtec. What head are you running? bone stock bottom end? It depends on several factors such as your pistons, block/deck clearance, type of head, thickness of headgasket.
Old Apr 21, 2011 | 08:53 AM
Mr. EG's Avatar
Read the original post you idiot. He has a P-72 casting on a stock LS bottom end. Your compression is roughly 10.0-10.1:1 (which is very similar to a USDM Gs-R motor).
Old Apr 21, 2011 | 09:13 PM
i dont know much but i got 150 on my 1st cylinder,150 on my 2nd cylinder,120 on my 3rd,180 on my 4th.... is that bad????
K7-1Ktrevor
Aug 24, 2009 03:40 PM
NOkTURNAL07.jp
12
Jul 2, 2006 10:22 AM
punkracer
Dec 2, 2005 08:19 AM
MugenGSRb18
Sep 7, 2004 12:43 AM
