B16 on P28
Old Nov 25, 2005 | 10:05 AM
gutted-dx's Avatar
Default B16 on P28
My p30 is some how fucked up and it idles like it needs a IAC but as soon as i swap out the ECU it stops. My friend has a P28 could i go with that until i get it chipped or would it run it lean, and also the other 2 ecus were chipped would that have anything to do with fixing my idle, that a stock p30 wouldn't do.
Old Nov 25, 2005 | 10:15 AM
Vtec-Mike's Avatar
Default Re: B16 on P28 (gutted-dx)
You could do a chipped p28, but what program is on the chip will contour how much fuel you'll get.
Old Nov 25, 2005 | 10:16 AM
Vtec-Mike's Avatar
What is the car doing exactly (As far as idling??)
Old Nov 25, 2005 | 10:32 AM
Equilibrium's Avatar
* B A N N E D *
P28 will run it fine, you wont blow your motor, you just wont unlock the potential of the motor until you get a better "basemap".
Old Nov 25, 2005 | 11:28 AM
nighttrain33's Avatar
Default Re: B16 on P28 (Equilibrium)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Equilibrium &raquo;</TD></TR><TR><TD CLASS="quote">P28 will run it fine, you wont blow your motor, you just wont unlock the potential of the motor until you get a better "basemap".</TD></TR></TABLE>
Do you think that a P72 would work better for the time being? I remember after I swapped for my B16, the P72 I was using at the time was "ok." Not like my 30, but it took care of business. I know a lot of people use chipped 28's, but is a stock one ok for our motor?
-Shane
Old Nov 25, 2005 | 11:49 AM
white92eg9's Avatar
i ran a p28 with a skunk2 chip in my b16 and it ran fine, but my motor didnt like p30 at all, for some reason either
Old Nov 25, 2005 | 11:54 AM
Luserkid's Avatar
Default Re: (white92eg9)
A stock one will be fine until you get the correct ecu. But i wouldnt run it longer then a month, or if you do alot of driving 2 weeks.
Old Nov 25, 2005 | 12:14 PM
gutted-dx's Avatar
I don't plan on driving it that long but why do you say not to drive it that long
Old Nov 25, 2005 | 12:23 PM
Luserkid's Avatar
Default Re: (gutted-dx)
Because the fuel and timing map will make it run leaner then what its suppose to. Anything other then what its suppose to be is bad for the motor and could lessen the lifespan of the motor.
Old Dec 16, 2005 | 07:55 PM
papito_85's Avatar
Default Re: (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Because the fuel and timing map will make it run leaner then what its suppose to. Anything other then what its suppose to be is bad for the motor and could lessen the lifespan of the motor. </TD></TR></TABLE>
so what ecu would be better to run?
Old Dec 16, 2005 | 08:56 PM
2000EM1's Avatar
Default Re: B16 on P28 (nighttrain33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nighttrain33 &raquo;</TD></TR><TR><TD CLASS="quote">
-Shane</TD></TR></TABLE>
I think a p72 on a b16 would give a CEL because the p72 also runs the GSR's IABs... which the b16 doesn't have. A basemap programmed/chipped P28 wouldn't hurt the car at all.
EJ SIR
14
Feb 19, 2009 01:55 PM
ivan93egreppin210
Dec 12, 2008 05:51 PM
anthonylee29
May 28, 2005 11:24 PM
B6teen
Apr 25, 2005 01:39 PM
advanracing62
Sep 28, 2002 09:54 AM
