Help Map Sensor
Old Nov 25, 2005 | 08:11 AM
Cprace1's Avatar
Default Help Map Sensor
What the car is doing about is about a 1000rpm pull the map sensor code comes on we have pulled the starting at 3000rpms and 5000rpm it seems to be the length of the pull that does it not the RPM or the boost leval the car is seeing 10.5psi on two diffrent boost gauges, I have swapped out hondata boxes both having bost on them no change, swapped out map sensors no change, checked and rewired mapsensor no change, swapped ECUs nothing seems to help, I thought it was wierd because it is neither doing it at RPM level or boost level the car does the same thing at 7.5psi as 10.5psi the car just hits a dead spot and the map sensor code comes on any ideas?
turboed rhd
Mar 17, 2010 08:47 PM
teg_95
Apr 28, 2009 07:19 PM
si_motor_spt
Sep 9, 2007 12:31 PM
See Are X
Oct 13, 2005 04:10 PM
420aNT
Jun 2, 2003 11:00 AM
