so what other cars suspension will work on my DA?
Old Nov 25, 2005 | 12:03 AM
. M i c h a e l's Avatar
dotmichael to you
Default so what other cars suspension will work on my DA?
i tried searching..but couldnt really figure out what to put into it.
i've heard some EF parts will work with my integra. i'm mainly talking about shocks. would it work? or would i need to modify something? (which always make anything work)
Old Nov 25, 2005 | 05:07 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: so what other cars suspension will work on my DA? (. M i c h a e l)
I think DC stuff will fit with proper complimentary DC part ie rear lca and front knuckles/forks...at least I THINK...bump for a GOOD answer.
Old Nov 25, 2005 | 08:24 AM
Monkey Z.'s Avatar
DC/EG will fit as long as you get the front forks (that's all you need besides the coilovers obviously).. if you get ITR suspension then you need ITR rear LCA's
Old Nov 25, 2005 | 08:29 AM
dotmichael to you
Default Re: so what other cars suspension will work on my DA? (DAantagonist)
Old Nov 25, 2005 | 10:14 AM
Moogen Powah's Avatar
EF shocks should bolt up directly on the fronts and rears. And as stated before, to use DC/EG shocks, you have to get some DC/EG front drop forks. Here is also a nice thread from G2IC on hybrid suspension: Click
Old Dec 2, 2005 | 11:17 PM
dotmichael to you
Default Re: so what other cars suspension will work on my DA? (Moogen Powah)
Old Dec 3, 2005 | 12:41 AM
riceball777's Avatar
any ef/eg/dc supension will bolt up
you need to match the correct front shock forks 90-93 integra or the the bigger dc ones. most likely the drops will be different because it was designed for a different car and spring rates will be different but if you have coilovers you will be fine
https://honda-tech.com/zerothread?id=1152522
Modified by riceball777 at 10:48 AM 12/3/2005
therest
Jan 5, 2012 08:18 PM
ef_hondas
Feb 5, 2010 11:10 PM
Blacklabel182
Suspension & Brakes
Oct 5, 2006 10:11 PM
Integra_B18B
Dec 1, 2004 06:47 PM
JDMef_typeR
Sep 22, 2004 12:00 PM
