primer no blndo!?
Old Nov 24, 2005 | 11:16 PM
nekoabandoned's Avatar
Default primer no blndo!?
i just grinded and sanded all the rust off my car is it ok to just prime over it without using bondo?
Old Nov 24, 2005 | 11:20 PM
Bond's Avatar
Default Re: primer no blndo!? (nekoabandoned)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned &raquo;</TD></TR><TR><TD CLASS="quote">i just grinded and sanded all the rust off my car is it ok to just prime over it without using bondo?</TD></TR></TABLE>
Bondo is used as a filler to fill in any low spots on the body.
Old Nov 24, 2005 | 11:33 PM
Default Re: primer no blndo!? (Bond)
so is it ok not to bondo till i can afford a paint job?because i did all this today and was wondering if its ok to just have primer for a month or two.
Old Nov 24, 2005 | 11:48 PM
Bond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nekoabandoned &raquo;</TD></TR><TR><TD CLASS="quote">so is it ok not to bondo till i can afford a paint job?because i did all this today and was wondering if its ok to just have primer for a month or two.</TD></TR></TABLE>
yup, just make sure to resand it before you bondo it and do the final prep work before it goes in before paint.
Old Nov 25, 2005 | 05:43 AM
JDM-EJ1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bond &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly. Get the body as smooth as possible.
Old Nov 25, 2005 | 07:02 AM
nolimits's Avatar
If it's permanet, you should etch bare metal before primer. It sounds like a temporary fix, so you could use any paint/primer to protect the bare metal for now.
Old Nov 25, 2005 | 07:12 AM
BiG Chris's Avatar
yea if its temp then you can slide b, if not you should use a sealer/etch then primer
Old Nov 25, 2005 | 11:20 AM
Default Re: (BiG Chris)
ya its just temp till i get enouf money for paint thanks guys
Old Nov 25, 2005 | 12:11 PM
Team Rukus's Avatar
use etch primer.
or even zinc primer.
especially cuz of the winter.
unless your going to fix it before the winter is over.
Old Nov 25, 2005 | 03:41 PM
william72364's Avatar
if you deceide to bondo i would use the bondo with the fiberglass hairs and if you prime it yourself before it gets paint i would use filler primer and wet sand
WangstaCivic
Paint and Body
26
Apr 30, 2008 09:08 AM
fishieman
Paint and Body
May 25, 2007 03:48 PM
Alberto D
Paint and Body
15
May 1, 2007 12:31 PM
GreddyTegra
Jul 13, 2006 10:37 PM
TheNasty0ne
30
Sep 10, 2005 06:30 AM
