Final gear or differentail dimension ?
Old Nov 24, 2005 | 11:16 PM
gilou bilou's Avatar
Default Final gear or differentail dimension ?
Hello,
I study the possibility to fit an ITR LSD on my Y1 gearbox with some machining.
In order to make a good study of the machining, i need some dimensions of the ring gear or differential. In fact i need the PCD of the bolting and the inside diameter of the ring gear. See pics:
If somebody have a differential or ring gear out of the gear box ? Please help me
Old Nov 25, 2005 | 02:31 AM
Downey's Avatar
Default Re: Final gear or differentail dimension ? (gilou bilou)
i cant remember if the Y1 has a 4.4 OR 4.26 final drive.
If its got a 4.4 (same number of teeth as the type r) then you should be able to swap the itr diff and ring gear into the y1 with just a small bit of maching.
the b16 size diff in the y1 is just a tiny bit smaller (pcd) than the itr. ive got both at my shop. ill look tomorrow and take some pics if i can find them.
Old Nov 25, 2005 | 05:33 AM
Default Re: Final gear or differentail dimension ? (Downey)
Thanks a lot !
My final gear is 4.266 and i want to machine the inner diameter to the same as the ITR and re-drill 10 holes on the good PCD to fit an OEM ITR LSD. Because, it's the cheaper solution for me to put an LSD in my tranny ...
And i dont want to change my tranny because i have a custom 3-4 and 5 th gears very shorts ....
Old Nov 28, 2005 | 03:42 AM
Up !
Steeve_Civic
Nov 25, 2011 12:23 AM
fourdoorturbo
Apr 30, 2007 02:16 PM
Boostin Ex
Dec 22, 2006 04:02 PM
NightHawkC5
Feb 28, 2003 07:36 AM
