GearBox Help
Old Nov 24, 2011 | 11:22 AM
Steeve_Civic's Avatar
Default GearBox Help
Could you advise me the Gearbox for Drag Racing with 550HP please?
I run a S9B gearbox at the moment.
1st question, How can I recognize it is a real S9B gearbox?
S9B Gearbox Ratios should be:
1st Gear 3.230
2nd Gear 1.900
3rd Gear 1.360
4th Gear 1.034
5th Gear 0.848
Final Drive 4.266
What about ITR Gearbox Ratio?
Thks
Old Nov 24, 2011 | 12:09 PM
Robs_B18c's Avatar
Default Re: GearBox Help
That trans should be fine for 550whp. Only really way to tell what trans it is, is pull it out, open the case and count the teeth on the gears.
Old Nov 24, 2011 | 09:47 PM
Thank you, But I don't want to open the gearbox!
Where can I find ITR Gearbox ratio?
Old Nov 25, 2011 | 12:23 AM
david974's Avatar
The S9b has LSD from factory
so when you look into the differential hole it should be empty
if not (see an cylindrical piece of metal) it's not a s9b
it's on of the best tranny for turbo long gear
Rickvanuden
Transmission & Drivetrain
Jun 8, 2017 09:00 AM
MySiIsRed
Jun 5, 2013 10:22 AM
teamasr1
Mar 21, 2010 09:31 PM
jdmkid8383
Jan 3, 2008 06:50 PM
hooptie157
Oct 19, 2002 02:22 AM
