Refilling trans fluid B16 HELP!!!!
Just got some synchromesh, and have all the fluid out. Now im stuck with a tranny with now fluid or any clue about how to get the new stuff in...Other then the 1/2 inch bolt on the side of the tranny behind the passenger side wheel, but it doesnt look like it would work out too well...where do I put it in!!!!
im such a noob
im such a noob
you drained it out of the 3/8 square drive correct?
If so put that back in after everything drained and look up about 7 inches and back about 4 inches. There should be a bolt that has a 17mm head. Its right under or near the passenger side axle. Take that off and thats where you fill it from. Its going to be a bitch to get it in there without spilling it so some clear hose shoved in the hole will make it easier for you. Let me look for a pic for you.
if you got regular syncromesh you got pretty much honda mtf, if you got the FM you got the good stuff. and take the fill plug out of the side of the trans by the axle, and fill it till it pours out of that plug, then put it back in and drive away
https://honda-tech.com/zerothread?id=382416
hope this helps. if you dont want do it through the vss hole, in the 17th pic down the bolt that is rign next to the axle there is the fill hole.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xEnderx »</TD></TR><TR><TD CLASS="quote">
Side note: take that synchro-crap back and get regular Honda MTF.</TD></TR></TABLE>
I used both and I hate HONDA MTF
Yeah, fill it thru the VSS...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typeoneeg6 »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=382416</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aka »</TD></TR><TR><TD CLASS="quote">I just bought a funnel that had a hose attached to it.</TD></TR></TABLE>
ya that would have been smart...but we were retarded and got bored on thanksgiving so nothing is open.
IM on my buddies computer so dial up is a pia when it comes to load time...
Ya i got the friction modified stuff...I got 2 quarts...how much should i put in??
take the fill plug out! fill it till it comes out of the fill plug!! and use a funnel with a garden hose attached to it, not that hard to figure out your both probably drunk
dammit...will it be bad to run it on 2 for a few days till i can pick up some more?
and the filler plug? im still a little clueless
on step 15 of the above mentionned link...is it that half inch drive bolt?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetEG »</TD></TR><TR><TD CLASS="quote">haha im just a newb...the fill plug is the half inch drive bolt? on the side of the tranny?</TD></TR></TABLE>
yes sir/mam/mistress whatever you like to be called
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetEG »</TD></TR><TR><TD CLASS="quote">It would be sir.... unless its a thursday...then its mam
j/k thanks for all the help....</TD></TR></TABLE>\
haha nice
no problem dude, hope it works out for ya
don't hesitate to ask anymore questions you have through pm or whatever, but i won't respond this week i'm gonna be out of town
haha nice
2lobes1engine
26
Jun 29, 2004 08:27 PM
