Oil Pump installation
well, my oil pressure is low. i cant get past like 50 psi or something at like 4k rpm, and my vtec isnt engaging. i'm pretty sure it my oil pressure, just replaced the solenoid with a known working one. at idle my oil pressure is under 20, i think its like at 10 or 15 psi. its either that or my oil pickup thing may be clogged. what u guys think?
how would i clean the pickup? just take off the oil pan right? i can just use a brush or something to clean them? its wierd cause not too long ago, my vtec was just fine and everything but now its not engaging and i was looking at my oil guage and i compared it to the prelude manual and its pretty low. i know for sure that the solenoid is working and everything and pretty sure the wiring is good. i'm just hoping its the oil pressure.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SteveoBA8 »</TD></TR><TR><TD CLASS="quote">is the pan dented?</TD></TR></TABLE>
a bit
a bit
Replace the pan and get back to us. I'm sure a used pan in good shape is easy to get ahold of at a local junkyard for cheap.
*edit* even if it's dented a little right where the pickup is it can effect the oil pressure to the point of VTEC not engadging.
