field vtec controller
Old Mar 12, 2002 | 05:32 PM
Ignitecivic's Avatar
Default field vtec controller
do anyone have the field vtec controller manuel in English, cuz i dont know how to adjust it and wat those numbers mean.
also if i reset the ECU or unplug battery, do the controller reset also...
Old Mar 12, 2002 | 05:54 PM
Waruy0i976's Avatar
New User
Default Re: field vtec controller (Ignitecivic)
i have the Fields... when you reset the ECU or disconnect the battery, the Field's settings still stay... what functions do you need to know??
[Modified by JDM SiR-II, 9:54 PM 3/12/2002]
Old Mar 12, 2002 | 07:15 PM
Default Re: field vtec controller (JDM SiR-II)
i want to know how i suppose to recalibrate the idle rpm, mine vtec controller reads at 400rpm, but my gauge reads at 700rpm. how i suppose to adjust that. is it from behind of the controller.
wats ur rpm idle at in ur controller. can u give me ur setting.
thx alot
Old Mar 12, 2002 | 07:30 PM
Waruy0i976's Avatar
New User
the rpm should be correct, usually the cluster is off by 200-300 rpm... i used to have a Autometer tach... if the Field read 1000rpm, the gauge cluster was about 1200 and the Autometer at 900... so there is some varience... the DIP switches tells the Field wether is for a honda motor or mitsubishi motor plus turning on/off the speed limiter...
btw: what motor do you have??
Old Mar 12, 2002 | 07:31 PM
Zeus Zore's Avatar
i would say your RPM gauge is fucked... cause normaly it only read off after like 6000RPM with like maybe 300 RPM +-
the field just tells you what the ECU are saying.... i would trust the field if you have conneted i the right way...
good luck..
?? where do one fin the field cheapest !?!? i would like one....
LOL .... nice going, same answar...
[Modified by Zeus Zore, 5:33 AM 3/13/2002]
Old Mar 12, 2002 | 07:54 PM
Default Re: field vtec controller (Zeus Zore)
alright then.
thx.
that means mine is correct. its below 300-400rpm from the controller
Old Mar 12, 2002 | 08:09 PM
Zeus Zore's Avatar
but would say your idle is low .......
Old Mar 12, 2002 | 08:40 PM
on vtec mode wat does the 99-b stand for
on sfc mode wat does the 0-1 stand for
can anyone help me.
Old Mar 13, 2002 | 05:51 AM
Waruy0i976's Avatar
New User
can anyone help me.
b-stands for buzzer
0-1 is the percentage +/- fuel at a given rpm range (the the arrow is red, that's increasing fuel (rich)/ if the arrow is green, that's decreasing fuel (lean))
ex: R2-3 is 2% increase in fuel from 3000 to 3999 rpm, G3-4 is 3% decrease in fuel from 4000-4999 rpm
my last settings were: 0-1 thru 0-6, G4-7, G4-8 : VTEC 5800/ Buzzer at 7900 - mods are K&N filter, DC 4-1, and Apex-i WS netted 145whp/101 ft-lb wtq and baseline was 141whp/99 ft-lb wtq
Old Mar 13, 2002 | 07:51 AM
thanks everyone. it really help me to know what's my function are.
i got one more question. does the vtec kik in point goes by the controller and the rpm in the controller
or
do it goes by the gauge cluster. since the controller rpm is below the gauge rpm.
Old Mar 13, 2002 | 09:17 AM
Zeus Zore's Avatar
it will kick in at the controller RPM !!!
you clusther is anyways showing bad RPM
b16a4
Jan 21, 2007 08:33 AM
