Rear Brakes Upgrade !!!
Re: Rear Brakes Upgrade !!! (happyclown_69)
Assuming it's a coupe, you want 99-00 Si LCA's, rotors, master cylinder, proportioning valve etc. Dunno about 4 doors
Re: Rear Brakes Upgrade !!! (beatdown88hf)
i believe that they will because in scc they put the crx si rear brakes on their project eg hatch. gsr brakes fit on the 5th gen hatch and the 6th gen coupes. so i think that the crx ones would fit since they fit on the 5th gen hatch. catch what im tryin to say?
Re: Rear Brakes Upgrade !!! (civicdisobedience)
Re: Rear Brakes Upgrade !!! (cjames235)
Re: Rear Brakes Upgrade !!! (Guardson3r3)
and also people take 1gen integra brakes and put them on their crx's, so that should mean that they will fit on civics too.? you could probably pick up some of those for real cheap.
Re: Rear Brakes Upgrade !!! (B_s)
All 5th and 6th Gen Civics/Del Sol/Si/SiR and 3rd Gen Integra/Type R rear disc brakes will swap as a bolt on. You may need different parking brake cables but you do not need to swap the booster, master cylinder or proportioning valve to do this upgrade.
==> http://home.mpinet.net/t-hero/DiscBrakes!!.htm
Global Moderator
crx's don't have rear brakes.
[Modified by rookie2nr, 12:57 PM 3/13/2002]
Project T
10-10-2008 08:12 PM
h22civ
12-07-2006 03:29 PM
Gumbey75
01-15-2005 12:50 AM
