question about the 5th gen ecus
From: united states of mexico and yes ladies i am, available
i heard there was a difference between the 97-01 ecus some thing like if you use a newer year ecu in a older modle car you will have a problem turning the car on when you fill up the tank i need to know if i can use a 99 ecu in a 98 lude and if it matters both are automatic
thanks
ray
thanks
ray
the immoblizer wasnt a problem when i had to swap from an auto ecu to 5speed ecu the mechanic just reprogamed it but i used the same year ecu so i didnt worry about anything else, i cant remember who it was on here that said the new one where different from the older ones and he knew cuz he programs and chips ecus
i think you're talking about how the ones from 97-98 are detuned making it 190hp and the ones from 99-01 are tuned to 195hp
hmm no not that im just woried if the car will ever have a problem turning on or not running rite for any reson
