Ecu from a junk yard?
Old Dec 4, 2004 | 11:58 PM
ItalynStylion's Avatar
Default Ecu from a junk yard?
In my parts list for the manual swap it said that i can use the ecu from my auto but the manual ecu is preferred. When i was in the junkyard getting parts out of a wrecked 5th gen i was wondering if the ecu in the car would work for me. The car was totaled when it was hit on the front left fender. How fragile is the ECU, any chance its still intact. Also...is its little compartment sealed from water? Its been raining here and the junkyard obviously isn't covered.
Old Dec 5, 2004 | 12:08 AM
makavelli1227's Avatar
yes, but you will have to also find the key for it, since it needs that authorization code too.
Old Dec 5, 2004 | 08:57 AM
2point2's Avatar
the ecu should be alright. My p13 looked like an engine fell on it and it still worked great. I've pulled ECU's out of cars burried in snow and they were still fine.
No comment about the 'key' though.. not sure what year that started?
Old Dec 5, 2004 | 08:58 AM
Default Re: Ecu from a junk yard? (ItalynStylion)
Can anyone explain this "key" thing to me, I have no idea what that is.
Old Dec 5, 2004 | 09:09 AM
pentaq's Avatar
You have an immobiliser in ECU in 5 gen, so you need immo unit suitable to this ECU to start the car.
Old Dec 5, 2004 | 09:10 AM
Gerhard_001's Avatar
5th gen ECU's have an 'immobilizer', which means there is a key with a specific code that is programmed into a chip, in the key and is required to start. No key, no start.
Old Dec 5, 2004 | 10:05 AM
Default Re: Ecu from a junk yard? (Gerhard_001)
I get what your sayin, but when you say key do you mean a physical key? Also if i were to get this ECU and didnt have the "key" is there a way i could get it or have honda reprogram the ECU?
Old Dec 5, 2004 | 10:12 AM
v4lu3s's Avatar
RTFM
mist junkyards leave the keys in the ignition.
and they will oftne back an ecu, basically it will work or they replace it or give a refund.
Old Dec 5, 2004 | 10:23 AM
JSR's Avatar
JSR
Default Re: (v4lu3s)
Can't u also go to the dealer to get the ECU flashed?
Old Dec 5, 2004 | 10:56 AM
ImportRicer's Avatar
Default Re: (JSR)
i dont think that would work
Lude81
Aug 21, 2012 09:14 PM
gerhard
Apr 16, 2012 01:58 AM
TofuCandy
Nov 26, 2011 12:19 AM
94SuperLudeSI
Aug 8, 2005 04:45 AM
vtec92lude
Oct 1, 2004 03:19 AM
