limiter at 5k
Old Nov 23, 2005 | 03:46 AM
Quade's Avatar
Default limiter at 5k
I'm experiencing a limiter at 5,000 rpms. What could it be? No codes at all. Check engine light is working.
Old Nov 23, 2005 | 03:50 AM
MadCityLude
Guest
Posts: n/a
Default Re: limiter at 5k (Quade)
Your ecu seems to be runnin in LIMP mode!
Are you throwing a CEL?
Old Nov 23, 2005 | 03:54 AM
The Weather Man's Avatar
Default Re: limiter at 5k (KillaLude92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillaLude92 &raquo;</TD></TR><TR><TD CLASS="quote">Your ecu seems to be runnin in LIMP mode!
Are you throwing a CEL?</TD></TR></TABLE>
..........<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quade &raquo;</TD></TR><TR><TD CLASS="quote">I'm experiencing a limiter at 5,000 rpms. What could it be? No codes at all. Check engine light is working.</TD></TR></TABLE>
Reading owns both of us........
Drive around at different loads - let the engine break(engine break) sometimes........even at high rpms.........something has to trigger the check engine light......but the light won't come on until it has to actually use the sensor or whatever.
Old Nov 23, 2005 | 04:01 AM
MadCityLude
Guest
Posts: n/a
Default Re: limiter at 5k (TheKingPin)
yea I think it time for bed! its been a long night and I aint gonna be much help to anyone this tired.
Good luck
Old Nov 23, 2005 | 12:20 PM
gtofighter's Avatar
ummmm are you sure that you are running it to 5000 rpms when the engine is warmed to proper temp. it wont let you run it over 5 grand if the engine is cold.
Old Nov 23, 2005 | 03:12 PM
Brown-tec's Avatar
Default Re: (gtofighter)
actually you can go over 5rpm when your engine is cold
Old Nov 23, 2005 | 03:59 PM
phoshizzle88's Avatar
Default Re: (Brown-tec)
yup i do it every mornin when im late
Old Nov 24, 2005 | 06:25 AM
Quade's Avatar
Default Re: (phoshizzle88)
The engine is at operating temperature. Still 5,000 rpm limiter. Feels good otherwise.
Old Nov 24, 2005 | 08:09 AM
MadCityLude
Guest
Posts: n/a
Default Re: (Quade)
Definatelly sounds like LIMP mode to me!
Old Nov 24, 2005 | 12:15 PM
Tippyman's Avatar
reset ur ecu and see if that does it.
ITRiWISH
11
Aug 27, 2007 05:24 PM
egturbolsvtec
Mar 15, 2006 03:20 PM
Alikat
Feb 20, 2005 07:27 AM
JDM00SI
Aug 25, 2004 05:42 AM
B_CRUZ!
12
Aug 10, 2003 04:05 PM
