My BOV is like my old lady...
...it wont keep its mouth shut. At idle that is. Is this normal for a Tial 50mm to sit wide open when the car is at idle (i.e. in vacuum). Do I need a stiffer spring? I've never used a Tial BOV before, so this is a new one to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoneedzvtec »</TD></TR><TR><TD CLASS="quote">im sure that is perfectly fine. correct me if i am wrong but the bov stays open under vacumm and closes under boost.</TD></TR></TABLE>
then itd never boost?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 »</TD></TR><TR><TD CLASS="quote">
then itd never boost? </TD></TR></TABLE>
Once the vaccum is gone, the valve closes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtremeazian »</TD></TR><TR><TD CLASS="quote">Once the vaccum is gone, the valve closes. </TD></TR></TABLE>
vaccum would never be gone?
oh yeah it would... it would go to 0. hopefully.
depends on the spring you have on your BOV. i think they made 3 different spring rates. I know i read about someone with the same issue last year some time and someone went into detail. If the BOV still vents during boost, then i wouldn't worry aobut it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Steve91 »</TD></TR><TR><TD CLASS="quote">...it wont keep its mouth shut. At idle that is. Is this normal for a Tial 50mm to sit wide open when the car is at idle (i.e. in vacuum). Do I need a stiffer spring? I've never used a Tial BOV before, so this is a new one to me.</TD></TR></TABLE>
you need a stiffer spring.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo@KAP »</TD></TR><TR><TD CLASS="quote">
you need a stiffer spring. </TD></TR></TABLE>
That's what I thought. My BOV is FULLY open at idle, not just a little bit.
tvrsir
Apr 24, 2004 10:33 PM
