No power to Ecu????
Old Nov 22, 2005 | 07:49 PM
MrMayhem's Avatar
Default No power to Ecu????
Whats up guys, i need some help, for some damn reason im not getting any power to my ECU. Any ideas? I put in new battery, alt., starter, all fuses are good, and still nothing? Any ideas will help. thanks
Old Nov 22, 2005 | 07:54 PM
ShadyBAB's Avatar
Default Re: No power to Ecu???? (MrMayhem)
The Wiring to the ECU may be corroded. Have you tried swapping out the ECU for another? You may want to do a voltage check.
RaysBoomBoomLude's Avatar
Check your transmission ground, I had the same problem kinda. and it was my transmission ground.
KraziCivicSi
Dec 22, 2007 10:07 PM
b18b ef boy
Nov 12, 2006 02:45 PM
Beau Gotti
May 16, 2006 06:36 PM
mockujin
Nov 14, 2002 07:43 PM
KevronsEG
Apr 21, 2002 01:49 PM
