Finally fixed my CEL code# 92 - Insufficeint Purge Flow
Old Nov 22, 2005 | 07:15 PM
many styles
Guest
Posts: n/a
Default Finally fixed my CEL code# 92 - Insufficeint Purge Flow
Alright, after 600+ bucks of work, replacing the charcoal cannister, the Purge control solenoid (twice) and all with no luck. I finally got the light to go away. And it was by accident.
After doing my auto to manual conversion, and changing my ECU, the CEL hasn't been on for 2-3 weeks.
So im guessing this has been fixed and I can finally go and do a normal Smog Check.
Can't belive that a tranny swap fixed my cel code #92. This light usually goes back on 2 days later after a ecu reset.
Its either that or the light went away when i changed my PCV valve.
Old Nov 22, 2005 | 11:20 PM
.M.'s Avatar
.M.
Default Re: Finally fixed my CEL code# 92 - Insufficeint Purge Flow (many styles)
I have the same problem. Duno how to ******* get rid of it but i did reset the ecu to smog the car and it comes back on 2 days later. Its just ******* annoying looking at the check engine light. i duno how to fix the problem
Old Nov 23, 2005 | 04:39 AM
97tegGS's Avatar
The PCV could restrict the flow and throw this code.
eclipsefirenos
May 18, 2009 10:11 PM
Sam268
Sep 13, 2004 01:11 PM
laNk_LinK
Jan 6, 2003 10:01 PM
smithbling
Nov 19, 2002 12:26 PM
S13 slide
Oct 8, 2002 01:23 PM
