The difference between EG and EK civic
Old Nov 22, 2005 | 05:23 PM
98gizzer's Avatar
Default The difference between EG and EK civic
I can guarantee you this question has been asked a thousand times, and I searched for the info with no real solid answer (unless I am blind), but I want to know the difference between the EG and EK civic. Are the LCA's the same? Are the shocks interchangable? If not is there a way to mix and match parts to make them fit? I have access to 3rd gen integra parts (98 GS-R) and want to basically know which model between the two will more parts fit on. (more so the suspension - by this I mean trailing arms,LCA's the whole thing basically, motor, tranny, seats) I hope this is an easy question. Thankx
Old Nov 22, 2005 | 05:41 PM
Anthony's Avatar
Mr. Fuch-yu
Default Re: The difference between EG and EK civic (98gizzer)
Someone correct me if I'm wrong b/c I'm not 100% sure, but I believe that if you are wanting to do some suspension swapping then you should go with a eg model. I believe that most of the suspension is interchangable between the two.
-Red
Old Nov 22, 2005 | 05:48 PM
SOHC4life 96's Avatar
Default Re: The difference between EG and EK civic (nitrared)
https://honda-tech.com/zerothread?id=1024818
My interchangeable thread. Hopefully this answers all your questions.
Old Nov 23, 2005 | 07:10 AM
Anthony's Avatar
Mr. Fuch-yu
Default Re: The difference between EG and EK civic (SOHC4life 96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC4life 96 &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1024818</TD></TR></TABLE>
Good **** here.
-Red
evo951
Apr 12, 2010 10:53 PM
Momentum
May 6, 2009 10:43 AM
MagnaniEG6
Jul 1, 2007 10:52 PM
Andyroo
10
Mar 9, 2007 09:51 AM
Demon_Dub
Sep 25, 2005 01:18 PM
