SUSPENSION question
SUSPENSION question
if i have itr 5lug on my 98 civic, will 94-01integra and 92-95civic suspension fit or do i still need to get 96-00civic suspension?
why do companies always distinguish pairing up products to 94-01integra/92-95civic and 96-00civics separately??? different products or what, if theyre all interchangeable?
Modified by Andyroo at 4:00 AM 3/7/2007
Re: SUSPENSION question (BLUIZE256)
Q: Can I fit EG or DC suspension (shocks/springs/coilovers) on my EK?
A: Yes, but it is not a bolt on affair. The front is interchangeable between the EG/EK/DC chassis, but the rears are slightly different. Anything made for an Integra Type R will not bolt up, but standard DC2 Integra as well as EG Civic shocks and coilovers will fit as long as you change out the lower shock mount bushing in the EK lower control arm for an EG bushing. The EG bushing is longer front to rear so in order for it to fit right without washers, get an EG bushing pressed in. Springs, on their own, are 100% swappable between any and every EG/EK/DC2 chassis.
quoted from clubek.net
Re: (Andyroo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andyroo »</TD></TR><TR><TD CLASS="quote">why do companies always distinguish pairing up products to 94-01integra/92-95civic and 96-00civics separately??? different products or what, if theyre all interchangeable?
Modified by Andyroo at 4:00 AM 3/7/2007</TD></TR></TABLE>
So they get you to pay more for the same ****. You'll need washers in the rear if you plan to use 94-01 Integra/92-95 Civic struts. But most companies will provide them since they are the same part numbers as 96-00 Civic.
Re: (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Enough to fill the space between the bushing and strut fork</TD></TR></TABLE>
sorry i ment what size washers
thanks
thanks
Re: SUSPENSION question (ek4_b16a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek4_b16a »</TD></TR><TR><TD CLASS="quote">Q: Can I fit EG or DC suspension (shocks/springs/coilovers) on my EK?
quoted from clubek.net</TD></TR></TABLE>
good ****, just the answer i was looking for, thanks
