accord misfireing
Old Nov 22, 2005 | 03:25 PM
asianalbutt's Avatar
Default accord misfireing
my 96 accord is misfiring. i brought it to autozone and they told me that spark plug one is misfiring. he told me to find spark plug one and clean it then disconnect the battery for about 10 min and it shoould be fine BUT i did all that and its still misfiring. the car wants to die out. when i drive the car shakes badly and the check engine light is on. i need help BADLY. can someone please help me ASAP????
Old Nov 22, 2005 | 04:26 PM
anyone??? plz??
Old Nov 22, 2005 | 04:47 PM
ujhonda's Avatar
Default Re: (asianalbutt)
OK I’ll tell you my way, call your best buddy
Remove the plug that not working
Clean it with a sand paper
Don’t install that yet
Insert that cleaned plug in to the plug wire
Find some rag and hold that plug’s body to car’s body (ground) ask you buddy to crank the engine
Can you see any spark? Oh good
No spark ? then remove Distributor Cap and Rotor and check the Ignition Coil with a digital multi meter, if distributor cap and rotor bad replace them as well
Hope this help
Oh if the Ignition Coil bad replace that too .
ooh check that plug wire too.. with you ohmmeter, measure resistance.
Old Nov 22, 2005 | 05:06 PM
im hopeing it will
Old Nov 22, 2005 | 06:17 PM
when i had broght it to autozone the code was 301? anyone have a clue??? any other suggestions i could fix my problem?
Old Nov 22, 2005 | 06:25 PM
BLKFLSH's Avatar
Did you change the plug? Unless you have a coil for each plug I think it would have to be the plug or the wire.
Old Nov 22, 2005 | 07:30 PM
the spark plugs are brand new
Old Nov 22, 2005 | 07:46 PM
BLKFLSH's Avatar
Well, the next thing to check would be the #1 wire. If you have a multimeter you can check the resistance. Sorry, don't know what it's supposed to read. Maybe check all four, and see if #1 is different.
Old Nov 22, 2005 | 07:52 PM
JTB's Avatar
JTB
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by asianalbutt &raquo;</TD></TR><TR><TD CLASS="quote">the spark plugs are brand new</TD></TR></TABLE>
what kind of plugs are you using?
Old Nov 22, 2005 | 08:21 PM
Default Re: (JTB)
they are bosch platnium sparkplugs
Old Nov 22, 2005 | 08:34 PM
SOHCMAN's Avatar
Everyone here is going to tell you that the NGK's are better, and its best to stick with stock plugs and other ignition goods unless you are heavily modified, and even then the NGK's work best (disclaimer, I'm sure there are cases that this is not true)
But, yes, check to see if there is spark before you do anything else.
sohc
Old Nov 23, 2005 | 08:32 AM
nickhans's Avatar
Default Re: (SOHCMAN)
i agree with him i had bosch platinum and my car was running ruff, so i baught NGK sparkplugs and they work. but anyways, you may be arching the wire, or just a bad cap and rotor, those r your only choises
Old Nov 23, 2005 | 02:32 PM
inomyhondas's Avatar
aside installing NGK plugs ,,,make sure the injector on that particular cylinder is working
Old Nov 23, 2005 | 03:31 PM
JTB's Avatar
JTB
Default Re: (inomyhondas)
for sure use the oem ngs and i bet your misfire will go away
Old Nov 23, 2005 | 03:58 PM
well i fixed the problem.....turns out it was my spark plug wires. they were gettin old and ****** up on me. my car runs great now but i think imma change it back to my ngk spark plugs i bought a while ago. see if theres any diff
Old Nov 23, 2005 | 04:00 PM
Default Re: (nickhans)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickhans &raquo;</TD></TR><TR><TD CLASS="quote">i agree with him i had bosch platinum and my car was running ruff, so i baught NGK sparkplugs and they work. but anyways, you may be arching the wire, or just a bad cap and rotor, those r your only choises </TD></TR></TABLE>
i think i kno wat u talkin bout the car running kinda rough.......the car kinda shakes when its idling. this is when i start up the car and let it sit..........like i said i think imma change it back to my nkg sparkplugs
Old Nov 23, 2005 | 06:08 PM
BLKFLSH's Avatar
Plugs or wires, simple really.
Old Nov 23, 2005 | 09:13 PM
imma change it back to my ngk plugs
Old Nov 23, 2005 | 09:14 PM
BLKFLSH's Avatar
Good idea.
azstunter13
Jul 17, 2011 11:11 AM
kenwolf
Nov 21, 2010 02:06 PM
Kyoto now
Aug 3, 2007 06:34 PM
k_spec
May 31, 2005 10:31 PM
JSpecwest
Dec 19, 2001 03:57 PM
