Cut Springs?
Old Mar 12, 2002 | 03:01 PM
89 CRX SI's Avatar
Default Cut Springs?
Should I do it or not? I figure even if it aint good then I can buy some new proper springs later. I've heard people say it makes your ride stiffer or "harsher" which is good but it increases body roll which is bad. Either way it'll look cool! Well how many coils do i cut to lower it 2.5"'s Thanks guys.
PS: Just got polyurethane Front/rear suspension kit installed (HANDLES SWEET !!!)
Old Mar 12, 2002 | 03:06 PM
martini's Avatar
Default Re: Cut Springs? (89 CRX SI)
so you ust installed your polys...don't **** up the handling by cutting the springs. Just LEAVE THEM ALONE. You will NOT be happy with them. Other than it will "look good" when sitting there.
Old Mar 12, 2002 | 03:07 PM
tdc's Avatar
tdc
why cut them.. the time it takes to take em a part and put them back in.... save your cash....your from kelowna right me too ...i just got a price from lordco for a 1.8 in drop $223 that not bad .then it`s done right the first time...
Old Mar 12, 2002 | 03:11 PM
89 CRX SI's Avatar
Default Re: Cut Springs? (tdc)
223 for all 4 springs??? NICE what's your ride ive prolly seen it
Mine is in the garage cause of frikken snow
Old Mar 12, 2002 | 03:46 PM
89 CRX SI's Avatar
Comon guys i need some info here.
Old Mar 12, 2002 | 05:01 PM
91HATCH's Avatar
my homeboi bought some coilovers ...dont know brand name but it looks likes skunks...he bought it for 100 at the aftermarket shop..the ride feels koo..i think its even better than skunks....
Old Mar 12, 2002 | 05:19 PM
redteg1's Avatar
Default Re: Cut Springs? (91HATCH)
CUTTING SPRINGS ARE FOR GHETTO REDNECK RICERS!!!!!
Old Mar 13, 2002 | 06:24 PM
crxd16a6's Avatar
Default Re: Cut Springs? (redteg1)
i bought my car and it had heated springs. They just heated them up on the car. It sets about 3 inches off of the ground and it rides great. They heated about half of the spring.
Old Mar 13, 2002 | 06:26 PM
89 CRX SI's Avatar
Default Re: Cut Springs? (crxd16a6)
Do you know any more infor on how they did this? And what is the gap between your wheel and your body piece? Ground clearence? Standard torch? How long does it drop while you heat it? etc.
Thanks
Old Mar 13, 2002 | 06:34 PM
EF'n's Avatar
i have seen a guy do heated coils on a rental before. he put some 2x4's under the car and took a torch to the coils and you could see the car drop then he just drove off. just spend the money and do it write.
Old Mar 13, 2002 | 06:38 PM
89 CRX SI's Avatar
Default Re: Cut Springs? (revhardracing)
I dont got the money i just spent 6000 on my REX now i cant get it lowered till june so i want to cut them. I heard that cutting is better cause itll be even compared to uneven heating method. Heated springs are supposed to be really bad in differentiating weather. I think ill just get an extra set of stock springs from bone yard for 10 bucks and cut them down a bit but how much of the coils do i cut?
I might have money if i sell my VW eibach springs ... mmmm an idea !
Old Mar 13, 2002 | 07:27 PM
DJ KrunchyKracker's Avatar
cutting coils ain too hard to do. just be sure that you cut the coil at the same spot where it previously ended before. each ring should be bout and in. give or take a lil. just take the springs and cut a coil and then try it. better to take the time and go slow with trial and error than cut too much the first time and be fucked.
Old Mar 13, 2002 | 07:46 PM
nawoj's Avatar
Default Re: Cut Springs? (TheRZA28)
cutting the springs will increase the spring rate of the stock spring, people with AE 86's do it because there isnt a quality aftermarket springs for there cars,
it is kind of ghetto when you can get quality springs from eibach and other such aftermarket companies...
do it right, or step off the platform...
Old Mar 13, 2002 | 08:37 PM
WuShu's Avatar
New User
Default Re: Cut Springs? (nawoj)
*smacks head and nods*
Will you just please save up and get some deacent springs. Free to cheap seems real nice till you break something else.
B_Swapped93
Jul 29, 2013 02:47 PM
ishnathan
Jul 3, 2009 07:08 PM
preludechick
Honda Civic (2001 - 2005)
28
Sep 14, 2006 05:48 PM
homeskillet
29
Jan 17, 2005 11:06 AM
90civichb
22
Dec 31, 2002 10:44 AM
