Head Light Assembly ;(
Old Nov 22, 2005 | 11:46 AM
ThaCivicAssassin's Avatar
Default Head Light Assembly ;(
93 EG
The assembly is a pain......I tryed replacing my bulbs which I did......The hard part is putting the lil assembly back on that holds the bulb tight. It looks like bent hanger wire........AnywayZ any suggestion on how 2 put these back on? I tryed removin the whole headlight and got it about half way out but then it gets stuck on something. I have a 4 door if it helps any thanks.......
Old Nov 22, 2005 | 11:59 AM
josh200536's Avatar
Default Re: Head Light Assembly ;( (ThaCivicAssassin)
You just have to keep workin with it. It took me @ least 30 mins to figure it out and get it back on the first time i changed out my lights.. Kind of a pain the ***..
Old Nov 22, 2005 | 12:07 PM
Default Re: Head Light Assembly ;( (josh200536)
I had it on the passenge side its not as bad. But then I popped it off trying 2 figure out how I did it so im back at square one. The driver side is almost impossible because there's no room 2 work.....The whole reason Im goin through all this is because my lights seemed focused on the ground like 7 ft in front of my car and no where else........Any other advice or are stock Eg lights desinged like this?
Old Nov 22, 2005 | 12:11 PM
xfletcherxx's Avatar
you could try completely taking the headlights out and see if you can figure it out a little better...
dmullinax96
Lighting
17
Feb 4, 2012 02:19 PM
kte324
Feb 15, 2010 12:17 PM
99CivicSiBrian
Dec 4, 2006 01:40 PM
Giga Crusher
Apr 24, 2005 05:22 AM
Screamer
Aug 3, 2001 03:11 PM
