annoying skeaky sound front left.... not sure what is causing it
Old Nov 22, 2005 | 11:20 AM
rkrone's Avatar
Default annoying skeaky sound front left.... not sure what is causing it
there is an annoying skeaky sound front left.... not sure what is causing it
it is coming from the drivers side front, it is rotational, but it is not from the motor, it only happens when im over 20mph, it gets faster with speed, not rpm, sounds like it might be inside, checked underneath steering wheel, but can't tell what it is while im not moving?
anyone have this problem ever?
its just frustrating because i don't know What it is coming From!
92 gsr
Old Nov 22, 2005 | 11:22 AM
ITB
Guest
Posts: n/a
might be a wheel bearing or something dragging like your brakes
Old Nov 22, 2005 | 02:26 PM
Deluzional's Avatar
Default Re: (ITB)
sounds like your brake pads are worn out and the metal shim is rubbing causing that sound
Old Nov 22, 2005 | 02:33 PM
rkrone's Avatar
Default Re: (Deluzional)
would that be only at certain speeds? could it be the rotors?
Old Nov 22, 2005 | 02:39 PM
Deluzional's Avatar
Default Re: (rkrone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rkrone &raquo;</TD></TR><TR><TD CLASS="quote">would that be only at certain speeds? could it be the rotors?</TD></TR></TABLE>
Ive typically had my brake pads squeel at lower speeds. Usually when coming to a complete stop. Well if your brake pads are completely worn down, it will warp your rotors and eventually start eating into it
Old Nov 22, 2005 | 04:29 PM
ripshot's Avatar
Default Re: annoying skeaky sound front left.... not sure what is causing it (rkrone)
Does the sound change any when you turn left or right at a low speed when you first hear the noise. You might have to jack up the front end (safely) and listen if it's the brake pads or bad CV joint or ?? Hopefully nothing serious...
Old Nov 22, 2005 | 05:08 PM
samuraijackass's Avatar
my car did that. it was a hub bearing in the end. Get it checked.
Old Nov 24, 2005 | 10:33 AM
rkrone's Avatar
it is not the brake pads, they have plenty of life left on them
Old Nov 24, 2005 | 10:37 AM
b17aprincess's Avatar
SPEEDOMETER HEAD!!!!!! mine does it too.... i'm pretty sure its the same part as on the civic si, so get the part number from acura, and buy it from honda. it's about 10% less. in northern va it runs about $160. doesn't hurt anything, just annoying as hell. how much you selling those headers for?
Modified by b17aprincess at 9:32 PM 11/25/2005
Old Dec 12, 2005 | 06:33 PM
rkrone's Avatar
Default Re: (b17aprincess)
so, its not coming from the suspension outside, it must inside, the spedometer head is something i haven't worked with... can it be fixed or does it have to be replaced???
and i'll sell the dc headers for $50
Civic_07
Mar 25, 2008 04:21 PM
mrtrinh
Honda Civic (2001 - 2005)
Nov 14, 2006 02:54 PM
redGSRguy
May 22, 2006 11:01 AM
kimota
Sep 26, 2005 01:23 PM
vietboixstunnah
May 10, 2003 01:00 PM
