car rolling back on hills when in drive!!!
Old Nov 22, 2005 | 08:56 AM
JDMDRAGON's Avatar
Default car rolling back on hills when in drive!!!
Wassup, one of my friends has a civic 4-door with the d15 and auto tranny....when the car is on a hill while in drive it will roll back and you have the balance the gas pedal to keep it from moving backward so we would have to keep the rpms up to 1700 just to balance it..it is really bad...
Any suggestions on what would it be???
Old Nov 22, 2005 | 09:08 AM
Archidictus's Avatar
Unceasing Measure
Default Re: car rolling back on hills when in drive!!! (JDMDRAGON)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDRAGON &raquo;</TD></TR><TR><TD CLASS="quote">Any suggestions on what would it be???</TD></TR></TABLE>
Normal. The torque converter can't provide enough torque on certain degrees of incline to keep the weight of the car from moving backwards. There's not a dowel that locks the car into a still position when you're on an incline, so the torque converter has to work to keep the car from rolling.
Don't be concerned. A 1.5L engine doesn't make much torque
Old Nov 22, 2005 | 09:09 AM
96CivicBoostCoupe's Avatar
if it is a really steep hill it could just be normal, if the force of gravity is greater than the force the engine can exert at idle, it will roll back
Old Nov 22, 2005 | 09:15 AM
cxSHOE's Avatar
lol this is normal man...
Old Nov 22, 2005 | 09:28 AM
dkim48's Avatar
Default Re: car rolling back on hills when in drive!!! (cxSHOE)
do his brakes work?
Old Nov 22, 2005 | 10:33 AM
Sic_DA_Nine's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDRAGON &raquo;</TD></TR><TR><TD CLASS="quote">Wassup, one of my friends has a civic 4-door with the d15 and auto tranny....when the car is on a hill while in drive it will roll back and you have the balance the gas pedal to keep it from moving backward so we would have to keep the rpms up to 1700 just to balance it..it is really bad...
hmaybe cause hes on a hill
Old Nov 22, 2005 | 01:03 PM
JDMDRAGON's Avatar
lol but u guys dont understand...i mean on the slightest incline it rolls back
Old Nov 22, 2005 | 01:33 PM
specialized108's Avatar
your tranny may be going bad
dose 1st gear slip at all?
if not i wouldnt worry about it too much unless you neutral bomb it
just use te e-brake until you get in the rpm's
anybody kno anything about the auto trans mine is slipping ***** and is pretty f&*(ed
kawaboy14
Honda S2000
30
Aug 15, 2007 01:18 AM
whitecrx
37
May 13, 2007 11:48 AM
16v
14
Mar 15, 2007 09:23 AM
dazcivic
Nov 29, 2006 06:40 PM
1SlowSi
Dec 20, 2004 01:43 AM
