h22 in eg which ecu do i use?
Old Nov 22, 2005 | 05:53 AM
typeRgazb18c6's Avatar
Default h22 in eg which ecu do i use?
hi there ive got a h22 out of a 93 prelude and i dont have the red key for the code!!!. this will b going into my 92 eg b16a2 shell.
i was running my b18c6 engine on my chipped b16a2 ecu will this run the 2.2 or not can anyone help me as am not that clued up please post all pics, info on wiring to this thread thanks.....
Old Nov 22, 2005 | 06:22 AM
Linh.'s Avatar
Default Re: h22 in eg which ecu do i use? (typeRgazb18c6)
p13... or if you want more tuning options go with a p28/p72
Old Nov 23, 2005 | 10:22 AM
jmayhew's Avatar
Default Re: h22 in eg which ecu do i use? (shooitslinh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shooitslinh &raquo;</TD></TR><TR><TD CLASS="quote">p13... or if you want more tuning options go with a p28/p72</TD></TR></TABLE>
X2
Old Nov 23, 2005 | 08:25 PM
EGmikeH22's Avatar
* B A N N E D *
x3
-and you dont need a key, use a piece of wire and just bridge the connector if you're talking about ECU codes. please proofread also, we need to know what you're talking about.
The b16 ECU wont runn your secondary bypass butterflies, but it'll work, you'll loose 7hp before vtec.
and the p13 or chipped p72 will work. i'm going forom a p13 to a chipped p28 right now!
Old Nov 24, 2005 | 08:56 AM
Vtec-Mike's Avatar
Chipped P28's are common in H22 civics
Old Nov 24, 2005 | 09:28 AM
high_revs's Avatar
p28
Old Nov 24, 2005 | 10:41 AM
Dueceification's Avatar
Depends on what your doing. My own preference is a p13 because its for the engine. But as far as tuning goes its tougher on the p13 because there is not a lot of support. Though I'd get a p72 ( or equavilant such as a converted p75 which would be cheaper to buy) to control those secondaries.
Old Nov 24, 2005 | 11:01 AM
EGmikeH22's Avatar
* B A N N E D *
Default Re: (VtecMike96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecMike96 &raquo;</TD></TR><TR><TD CLASS="quote">Chipped P28's are common in H22 civics</TD></TR></TABLE>
in civics with 7hp less down low
Old Nov 24, 2005 | 11:23 AM
99exd16y8's Avatar
Default Re: (EGmikeH22)
I am running a chipped p72 only b/c I have an aftermarket header that when installed need to get tuned, also with the p72 it with activate the IAB's.
[Posted by 24.25.49.151. This is added while posting a message to avoid misuse of WebWarper: see http://webwarper.net/han Example of using WebWarper: http://webwarper.net/ww/~av/ho...42044 ]
Old Nov 25, 2005 | 10:20 AM
Vtec-Mike's Avatar
Do they really make 7 less HP??? My h22 hatch was running a p13, but I have seen many p28 h22 cars.....I guess thats why I beat most of them.
Old Nov 25, 2005 | 11:31 AM
RotiEatter's Avatar
Ditto
P13-stock
P28/P72-chipped
I'm personally running a P05 Chipped with Uberdata,
h22eg607
Oct 3, 2007 08:42 AM
chicows18
Mar 11, 2006 10:39 AM
Myh4tch
Dec 14, 2005 04:03 PM
2Point2EH2
12
Nov 30, 2003 05:07 PM
tonesdef
Jul 18, 2003 08:22 PM
