My exaust was spitting something out..
So i went to start my accord(95) today, and when i got in, it was in park (obviously) i turned it on like normal, and i revved my enginge a little to warm it up, i pulled out of my garage and paked it in the driveway because i forgot my backpack in my living room so i had to run back in, and when i came out, i noticed my exause had spit out what looks like a dirty waterish liquid, and it smelled kinda funny, so im wondering.. is that bad?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Defcon2030 »</TD></TR><TR><TD CLASS="quote">exhaust leaks sometimes, especially when its cold out, the hot exhaust seperates from the rest forming condonsation. maybe mixed with rust</TD></TR></TABLE>
it isnt "leaking"...condensation forms inside the pipes after the car is shut off. it is more noticble when its cold, and if the car is driven often, but for just short periods of time
Here's a quick and simple way to check if your car has a problem oriented with exhaust.
After you drive the car for a little bit to clear out any condensation that may have formed from the cold weather. Take your finger and just run it along the inside of the exhaust exit pipe(inch or 2 inside). If it's dry then you're all good, if it's a little moist then you're still ok, your car is just showing signs of normal wear and tear. If it's wet or even oily then you got a problem.
-Mark
-Mark
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by icer5160 »</TD></TR><TR><TD CLASS="quote">Here's a quick and simple way to check if your car has a problem oriented with exhaust.
-Mark</TD></TR></TABLE> are you f*cking kidding me
you can come do that test for me.
