Anyone know the procedure for breakin in new pads and rotors (step by step)
Old Nov 21, 2005 | 02:48 PM
Cannon Man's Avatar
Default Anyone know the procedure for breakin in new pads and rotors (step by step)
Im about to replace my rotors and pads but before I do Id like to see if anyone knows the right way to break them in. ie; first stop 30-0, 2nd 30-0, 3rd 40-0 or something like that. Ive heard how to do it before but I dont remember exactly
Old Nov 21, 2005 | 04:52 PM
D21X's Avatar
Default Re: Anyone know the procedure for breakin in new pads and rotors (sexxyred6th)
dont know what the procedure is, but what i have usually done was get the rotors/pads really warmed up, i've done 60-0 stops like 6 times and my rotors and pads still look okay... btw this was both on my 91 accord (brembo blanks/hawk hps) and for my 92 civic (autozone rotors/axxis ultimates)
Old Nov 21, 2005 | 07:50 PM
iam7head's Avatar
Default Re: Anyone know the procedure for breakin in new pads and rotors (D21X)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D21X &raquo;</TD></TR><TR><TD CLASS="quote">dont know what the procedure is, but what i have usually done was get the rotors/pads really warmed up, i've done 60-0 stops like 6 times and my rotors and pads still look okay... btw this was both on my 91 accord (brembo blanks/hawk hps) and for my 92 civic (autozone rotors/axxis ultimates) </TD></TR></TABLE>
there's general rules but to be damn honest, theres no universal "the one" formula
Old Nov 21, 2005 | 08:59 PM
Cannon Man's Avatar
Cool, thanks fellas
Old Nov 22, 2005 | 04:16 AM
JimBlake's Avatar
Default Re: (Group A)
For the first hundred miles you should avoid clamping down the brake to a complete stop. Lots of people can't possibly do that in real-life traffic, so here's what to do. Find a time/place where the traffic won't get you in trouble.
Brake hard from 50 to 5. Repeat 10 or 20 times with a couple minutes between each for cooling. Don't stop all the way.
If you stop completely, clamping NEW brake pads down on a HOT rotor that isn't turning, the pad material imprints unevenly on the surface of the rotor. Then your brakes shudder & shake because of the uneven surface.
Old Nov 22, 2005 | 04:15 PM
AFAccord's Avatar
Default Re: (JimBlake)
Where are you getting this 'beat the **** outta your new pads and rotors' idea??? This isin't like seating new rings on a freshly honed bore of a rebuilt motor! Dude... take it easy on your pads and rotors for a while. Don't go testing them out at every light. Drive 200-300 miles at a minimum, just cruising like you old man would. You will feel the brakes start to firm up after they have worked their way to their settling point. Once you've hit 400 miles, you should be home free. Do what ever tha hell you want to them. Try some brake stands for all I care. But just don't go standing on the brake pedal until they're settled in.
JimBlake has the right idea if you want to give them a little try, but be certain that you don't clamp them as he's stated.
Old Nov 22, 2005 | 06:49 PM
Cannon Man's Avatar
Default Re: (AFAccord)
Alright, I think I got everything now. Thanks
Old Nov 22, 2005 | 07:26 PM
swsupermini.com's Avatar
Default Re: (sexxyred6th)
Not sure about the Stop hard method. The method I got when attending the "Mighty" Brake class was to not do any hard braking for at least 100 miles. Gentle and light giving yourself as much room as possible. Gently bed them in.
The "shudder" is cause by an uneven rotor but is is usually caused by excessive run out. Many times this is because of rust growth behind the rotor. Or when turned on the off car lathe you ended up with a couple of thou of run out and then mated it to an uneven hub and got another couple of thou of runout. combined its not much but after a few thousand miles its enough cause the pad to wear a spot in the rotor. When you have your rotor off you should sand the hub and inside of the rotor. This is why its better to turn you rotors on the car if you have the equipment avail.
Old Nov 22, 2005 | 08:15 PM
ujhonda's Avatar
I use Monroe Premium Brake Pads, man they rocks, I never had stopping power like this even with OEM brake pads.
Proper break-in is one of the most important factors in determining brake pad performance, as it seats the pads for optimum performance. MonroeŽ recommends 15 to 20 gentle stops from 20 mph. MonroeŽ Premium Brake Pads' positive molding technology does not require burnishing.
I got a good deal on them and now I know they are good
if you need more info on them here http://www.monroebrakes.com/support/faq.asp
btw I am not a Monroe sales men
93_hatchie
Suspension & Brakes
14
Dec 28, 2008 09:09 AM
HotDC5
May 9, 2005 08:41 AM
hans stoner
May 9, 2004 05:58 PM
B18CYAAA
Sep 21, 2003 02:09 PM
andrew n
Jun 18, 2002 12:04 PM
