My crx...
I had to go pick up some stuff from the home depot and all of that **** couldnt fit in my crx so I borrowed my dads truck.
I dont feel like explaining the whole story so heres what basically happened...
He forgot to turn off my headlights, the battery died.
He cracked the plastic around my battery terminal.
Acid leaked out so he bought a brand new battery.
The ******* thing still wont start, the car is 100% lifeless when I tried starting the car there was nothing but silence. It didnt even try to crank over.
But the car worked perfectly fine before my dubass dad drove it.
What do u think it could be?
Thats the last time i'll let that ****** drive my car.
Are the lights even coming on to indicate power?
If so, then I would check the signal wire on the starter, or the power lead to the starter. Come to think of it, it is more than likely the power lead to the starter not being connected to the battery.
In either case from above, the car will indicate power, but will not try to kick over the starter.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXb18Turbo »</TD></TR><TR><TD CLASS="quote">It's the big fuse that the power wire connect in the fuse box.
or your ground.
AND have a little more repect for your dad
... People leave their light on sometime.</TD></TR></TABLE>
When I was doing my swap all I heard from my dad was "you can't..." "not possible..."
"if it was that easy then everyone would do it..."
Then I did it. That shut him up for a while.
I can see where you're coming from.
or your ground.
... People leave their light on sometime.</TD></TR></TABLE>When I was doing my swap all I heard from my dad was "you can't..." "not possible..."
dudee
Nov 23, 2010 07:34 AM
9 CRX si 1
Nov 5, 2006 03:36 PM
RockLee`
11
Sep 3, 2005 03:49 PM
