vtec wiring question?
Old Nov 21, 2005 | 08:50 AM
blkhatch92's Avatar
Default vtec wiring question?
what are the 3 wires for on the vtec i need to know what each of them are for thx for the help.....
Old Nov 21, 2005 | 08:55 AM
UNDER PRESSURE's Avatar
Default Re: vtec wiring question? (blkhatch92)
Vtec noid
Vtec oil pressure
and knock sensor
Old Nov 21, 2005 | 08:58 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: vtec wiring question? (UNDER PRESSURE)
You will need to run a ground from the switch as well.
Old Nov 21, 2005 | 08:59 AM
blkhatch92's Avatar
Alright, thanks . . . . Any idea how i would go about wireing it into a toggle switch?
im not going to use it lok, im just curious if vtec will work . . i want to know befor i buy the necessary equipment to actualy make it work correctly.
Old Nov 21, 2005 | 09:04 AM
Default Re: (blkhatch92)
If you wired it right why wouldn't it work? Do it right or don't do it at all bro...
Old Nov 21, 2005 | 09:09 AM
blkhatch92's Avatar
thats the thing, i bought the car, its an a6 block wit ha z6 head, im not sure if the ran the oil lines or not so i figured i woudl try a toggle swithc, jsut to see if itd work or not befor paying to have my ecu chipped
Old Nov 21, 2005 | 09:17 AM
So what ecu are you running? and on the oil lines... what are you talking about, all you have to do is remove the oil jet from the block.
Old Nov 21, 2005 | 09:34 AM
blkhatch92's Avatar
i didnt put hte minime togetherr, therefore i dont know if the oil jet was taped so i want to hook up a toggle swithc to turn on vtec to find out if it works beforr buying anythng else to make it owrk
Old Nov 21, 2005 | 10:30 AM
FERIOkid's Avatar
the oil jet does not have to be tapped you only have to pull out a plug that is in it for the non-vtec motor. I put together a mini-me and it was a breeze. And you will definatly know if your VTEC is working or not so i dont think you should use a switch, just more wireing where something can go wrong. Just the right ecu, do an oil change with the correct amount of oil and there ya go.
Old Nov 21, 2005 | 12:55 PM
blkhatch92's Avatar
i know how to do a mini-me, all im asking now is if anyone knows how to wire it into a toggle switch, i dont need any flamming or what not, its a simple question . .
Old Nov 21, 2005 | 01:15 PM
Mario.'s Avatar
There's no reason to do a 'toggle' switch. That's retarded.
Wire it in the way it's supposed to be, get the proper ECU, and enjoy. Jeeeze man making this way more complicated than it needs to be.
Old Nov 21, 2005 | 01:17 PM
Okay your gonna buy a 2 prong switch... the noid just ground it to the chassis, then you need to run the signal wire from the noid to the spot wherever you're mounting the switch, then get a power source for the switch from the fuse box. There should be a empty spot for a female connector to plug in, when you find that spot run a wire from there to the same place you ran the noid wire to. Make your connections and you should be set... whenever you turn the key it powers the switch as an acc. then you just turn it on or off whenever you want.
Disclaimer:
I'm not responsable if you fry any of your *****!
Good Luck having to shift, hold the wheel, and turn on the switch all at the same time while paying att. to the road... or just always roll around with a buddy hand him the switch and whenever you want VTEC all you have to do is yell out, "VTAK!!1!!1!ONE"
Old Nov 21, 2005 | 03:27 PM
blkhatch92's Avatar
Default Re: (UNDER PRESSURE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNDER PRESSURE &raquo;</TD></TR><TR><TD CLASS="quote">Okay your gonna buy a 2 prong switch... the noid just ground it to the chassis, then you need to run the signal wire from the noid to the spot wherever you're mounting the switch, then get a power source for the switch from the fuse box. There should be a empty spot for a female connector to plug in, when you find that spot run a wire from there to the same place you ran the noid wire to. Make your connections and you should be set... whenever you turn the key it powers the switch as an acc. then you just turn it on or off whenever you want.
Disclaimer:
Good Luck having to shift, hold the wheel, and turn on the switch all at the same time while paying att. to the road... or just always roll around with a buddy hand him the switch and whenever you want VTEC all you have to do is yell out, "VTAK!!1!!1!ONE"</TD></TR></TABLE>
lol Alright man thanks, im not going to use it put jsut fo like 2 mins, just wanna see if vtec is gonna ingage
Old Nov 21, 2005 | 03:35 PM
blkhatch92's Avatar
thank you lol
Old Nov 21, 2005 | 08:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkhatch92 &raquo;</TD></TR><TR><TD CLASS="quote">thank you lol </TD></TR></TABLE>
No prob... lol. I even made myself laugh with that one, jajajajajajajaja...
puppet_828
13
Oct 30, 2012 08:25 AM
eddysmith2000
Aug 29, 2012 02:31 PM
got_no_sol
Apr 11, 2008 08:51 PM
dumpeDc2
Feb 25, 2005 06:08 PM
Patch
15
Jan 23, 2004 07:47 PM
