check engine light?
Old Nov 21, 2005 | 08:18 AM
eas156's Avatar
Default check engine light?
i read codes it is giving me high voltage and 02sensor then abs light came on speed ometer quit working and the whole car died? when it was running I was getting 10.5 v out of the alt.
Old Nov 21, 2005 | 10:25 AM
jdmcars.com's Avatar
Default Re: check engine light? (eas156)
Well, you should first tell use the car, model, year, and ECU you are running if something different than stock.
10.5V is not enough coming out of the alt for starters.
Old Nov 21, 2005 | 11:18 AM
eas156's Avatar
Default Re: check engine light? (jdmcars.com)
it is a 01 gsr stock ecu no mods other than header cat back and intake
Old Nov 22, 2005 | 10:30 AM
eas156's Avatar
ok guys found the problem I had a short in my o2 sensor wiring harness
PhatwhipsJDMkits
Nov 28, 2004 09:31 AM
JDMF22B
Sep 23, 2004 01:18 AM
huepowered
Jul 6, 2004 06:16 AM
ramz7887
Dec 3, 2003 09:44 PM
Defiant1999
Jun 3, 2003 10:41 AM
